belt change problem
Old Mar 30, 2006 | 08:06 PM
DodgeBullrider's Avatar
belt change problem
I;m tryin to change my belt . How do you get the plastic fan shroud off? Or dors it not come off?
Old Mar 30, 2006 | 08:13 PM
kandgo's Avatar
Welcome to DTR, There should be no need to take the shroud off. What are you working on, I would assume a Dodge with a cummins?? Just feed it around the blades and follow the routing that should be on your hood or radiator support somewhere. Goodluck,,Rick
Old Mar 30, 2006 | 08:38 PM
willysrule's Avatar
ditto, shouldn't be a need to remove the cover, sounds like more work...
DodgeDiesel61
Jan 26, 2019 07:45 PM
DodgeDiesel61
0
Jul 28, 2010 11:14 AM
apwatson50
Mar 3, 2006 06:26 PM
jeepsuck
Jan 2, 2006 03:41 PM
s-mcbride
Nov 23, 2005 08:36 PM
