Band Adjustment
Old Feb 2, 2008 | 10:07 AM
Tiara3100's Avatar
Band Adjustment
Trying to adjust the front band on my transmission. The directions from this site say to loosen the lock nut and tighten the bands to 72in. pounds and then back off 13/4 turns. The problem is it does not say which way is tightening. If I go clockwise, it does not get tight.
Am I correct in the assumption that the band screw goes counter-clockwise to tighten?
Old Feb 2, 2008 | 10:56 AM
John Faughn's Avatar
Well what I have in mind does not match what you said you read ,
After loosening the outer luck nut , you turn the center in snug / till it touches , then back out the 1 3/4 , while holding center bolt , torque the lock nut to 72 in lbs .
Its all right hand threads , so righty tighty , lefty losey .
I going to check my memory .
http://dodgeram.org/tech/transmissio...T_band_adj.htm
Old Feb 2, 2008 | 11:12 AM
CamperAndy's Avatar
John - You wrote the insturction wrong in your post as they do not match the instructions on Geno's.
Old Feb 2, 2008 | 11:37 AM
Tiara3100's Avatar
OK. I guess I figured it out...Just had to screw the adjuster nut in a little further (Clockwise) and then it tightened. Backed it off 1 3/4 and then tightened lock nut to 30ft Pounds while holding adjuster nut.
Old Feb 2, 2008 | 12:05 PM
Thats why I put the link , some times the brains has issues
Old Feb 7, 2008 | 10:19 AM
mmurray's Avatar
Yeah...
Tighten the center stud to 72 in/lbs... or for those not to good in math 6 ft/lbs... and back off 1 3/4 turns...
*(recomendation- do this very slowly if you are using a torque wrench set for ft/lbs... 6 lbs is very light and if you are not watching you'll go past it... Your not going to get that go ole snap like when your tightening at 30 ft/lbs... you'll probably not hear it or feel it... just watch the knuckle for when it breaks loose... otherwise you continue past 6 ft/lbs....)
Then hold the center stud and hand tighten the outer nut, so the inner stud doesn't turn... then tighten to 30 ft/lbs.....
Old Feb 10, 2008 | 01:29 PM
travelingman's Avatar
band adjustment
Is it not recomended too just adjust the outer band because of the way it goes back to first for the third gear shift . Also my truck is a 2001 an I am
thinking its the 47RE is there a tag or number on it somewhere that identifies it .?
Old Feb 10, 2008 | 01:35 PM
j-fox's Avatar
It is a 47re, no other options.
betsycam
Sep 26, 2004 03:44 AM
miketriton
Aug 20, 2004 01:14 PM
Outlaw02
Jul 8, 2004 10:16 PM
vtailflyer
Feb 1, 2004 06:43 PM
Dodgezilla
May 6, 2003 06:50 AM
