bad fuel?!
Old May 4, 2009 | 04:37 PM
Blackedout1ton's Avatar
bad fuel?!
so i recently picked up bad fuel some where along the line. after my truck ended up dying i took it down to our shop and pumped all the fuel and what i thought to be all the water. well right after my truck went to the shop and sat fior 2 weeks while the replaced a bunch of drivetrain stuff for warranty. when i left the truck it had 1/4 tank and when i picked it up it was next to empty. on my way home i grabbed fuel and after i left the gas station i blew a cloud of white smoke like you wouldnt believe. now it keeps stalling,. what to do now?
Old May 4, 2009 | 06:11 PM
could my injectors be shot? it smells like im burning raw fuel and my exhaust tip is actually moist ?
Old May 4, 2009 | 09:14 PM
muffdaddysram's Avatar
sounds like sucking air or not getting a enough fuel
Old May 4, 2009 | 10:24 PM
cincoup's Avatar
your transfer pump maybe pluged .
Old May 5, 2009 | 06:55 PM
elucho02's Avatar
Possible Injectors
Had very similar problem. Wound up being injectors.Pull up all my previous post to see how to determine if and how many injectors it may be...mine needed #4-#5-#6--replaced
Old May 9, 2009 | 03:35 PM
i know the problem was definately bad fuel because i pulled the filter and found water droplets. where do i go from here?
Old May 10, 2009 | 10:53 AM
duner's Avatar
if you only found a few drops of water bad fuel probably wasn't the problem. just a thought. good luck.
Old May 10, 2009 | 11:21 AM
thanx for all the input guys, im still trying to mess with this and figure it out. it doesnt make me any money sitting in the drive way
Old May 10, 2009 | 12:14 PM
rich's Avatar
03 has very delicate injectors, probably got damaged from the water
J10495T
36
Dec 12, 2007 03:37 PM
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
design
Mar 3, 2003 07:07 PM
