bad front end shaking please help
Old Aug 27, 2006 | 12:10 AM
hogboy's Avatar
cant drive my truck hit a bump with out it shaking me of the road and making me stop. changed my gearbox already tie rods are good and just bought my stabalizer shock "not yet installed" But still shakes. Any thing helps!!
Thanks, Tony
Old Aug 27, 2006 | 12:24 AM
53 willys's Avatar
Track bar ends??
have you tried this before?
I had them on my old truck and loved them.
http://www.lukeslink.com/
Old Aug 27, 2006 | 12:28 AM
jyama69's Avatar
Death Wobble
My 01 did the samething. It is called the dodge death wobble. I replaced the track bar and one of the steering components that had play in it. No problem after that. Have a buddy turn the steering side to side and watch for movement in any of the joints.
Old Aug 27, 2006 | 12:43 AM
Captain's Avatar
Specfically the top of the trac bar. Its a ball joint located under the driver side of the frame behind the wheel. There should be no play when you turn the wheel slightly side to side. Whatch it while someone wiggles the steering wheel. I'm willing to bet you'll see the cup move up and down a whole lot on that ball. I'd suggest getting the 03 tracbar conversion. I also went with duel steering stablizers and havnt had any wobble ever since.
Old Aug 27, 2006 | 12:49 AM
53 willys's Avatar
buy lukes link and save money, the Lukes link joints are rebuildable for like $8 bucks. If you replace just the OEM trac bar with another OEM trac bar it cost like $175 bucks with lukes link just by a rebuild kit and be done with it. if your running bigger tires then the trac bar will wear out faster then normal.
Old Aug 27, 2006 | 11:44 PM
hogboy's Avatar
Thanks guys tried most of the things u guys told me to look after and didnt see anything loose or with movement. I've had enough of the shaking and taking my truck to the shop to see what it is. I'll keep u guys posted thanks for every thing.
Tony
Old Aug 27, 2006 | 11:58 PM
strokethis600's Avatar
What tires are you running. I had the same problem and had basically everything in the front end replaced. then decided to put my stock tires back on (had bfg all-terrain 315) and the death wobble was gone, now i have a set of 305 toyos and still no death wobble.
Old Aug 28, 2006 | 12:14 AM
hogboy's Avatar
i have some pos super sport special ordered 235/85/16 trying to get new toyo's on my truck hurd they were pretty good. I'm going to have my truck alligned tomorrow morning and see if maybe its my tires causeing the death wobble.
Thanks,Tony
Old Aug 28, 2006 | 07:21 PM
mr T's Avatar
Thanks, Tony
i have a luke's like on a track bar end but unfortunately the last owner put a MOOG track bar on and i cant use my 2nd luke's link there and im developing play in my track bar...i can move it slightly up and down...anyone wanna toss their old stock track bar?
Old Aug 29, 2006 | 01:18 PM
Don Anderson's Avatar
I have a stock 95 and 01 trackbar that you can have for shipping.
Old Aug 29, 2006 | 06:51 PM
scottsjeeprolet's Avatar
Lukes link?
Tell us more about the link, where do you get them are they just the ends or the whole track bar.
thanks
scotte
Old Aug 29, 2006 | 07:02 PM
Earthmover627's Avatar
mine did the same thing. the pitman arm was shot. put on a new one and solved the problem.
Old Aug 29, 2006 | 08:24 PM
longbed's Avatar
Get the tires off the ground and move the tire in and out you must have a worn joint somewhere.
Old Aug 29, 2006 | 11:38 PM
hogboy's Avatar
Finally got rid of the death wobble guys seems the problem was my trackbar would slightly move side to side causing the wobble. what a relief that was even though thanks alot for every thing guys.
Tony
Old Aug 30, 2006 | 10:37 AM
53 willys's Avatar
thanks
scotte
Check the link out it tells you all about them
http://www.lukeslink.com/trackbar.html
it's all about rebuilding you tracbar for $16.00 bucks instead of $175.00 for a whole tracbar.
BTW it works for ALL the front end joints!
