auto trans only shifts 2nd & 3rd
hi
get it scaned with a odb II scaner and poast the codes .
most autozone / autoparts store will scan it for free!
if po743 i think showes up then erase the codes and try driving and see if they return .
Can you manually pull into low and get low gear?
Again it appears tranny is in limp in and some electrical issue is causing.
In reviewing, you have takeoff in second and shift to third.
Can be manually dowshifted to low and will upshift when move lever.?????
It has reverse and there are no ugly sounds coming from tranny.
If above is correct, then really need to see a smart dealership and have tranny signals read. From your statements all solonoids, transducer, temp sensor, outside speed sensor have been covered.
Did this happen AFTER your VB or tranny change to DTT??? There was some part # changes between 99 and 2000(1)that will wear you out on tranny electronics.
hi
po500 vehicle speed sensor malfunction !
p1693 dtc detected in companion jtec mod
p1694 no bus message recieved from ecm mod
prob the speed sensor , i would erace the codes and test drive and see if it comes back !
I had the same type of problem with a 47re
https://www.dieseltruckresource.com/...98#post2266398
call Dave he is good at finding problems over the phone.
put your truck info into your signature.
jshaw214
Mar 31, 2008 08:56 PM
jshaw214
Jan 5, 2008 09:15 PM
bigbaddiesel
Nov 23, 2002 02:33 PM
