Atf+4
Old Oct 12, 2004 | 09:37 AM
Toby's Avatar
Atf+4
I took my truck in to have the TC changed out and I asked about ATF+4. The guy say he never heard of it and they use Micron 4 or 5. My question is are they the same? If not I told the guy that I would go get it and bring it to them.
Toby
Old Oct 12, 2004 | 10:23 AM
Commatoze's Avatar
Micron 4 or 5? Are you sure they don't mean "Mercon"? There are 2 companys that I know of that make an ATF+4 equivalent. One is Amsoil, the other is Valvoline's MaxLife ATF. I believe ATF+4 is a Chrysler trademark so the bottle won't refer to the fluid in that manner. It can say ATF +4 compatible and I know it says so on the MaxLife stuff. Ive used it in my transfer case. Chrysler has a lock on ATF+4 and is using it as a way to squeeze more money out of its customers. BTW, I had my '02 in for tranny service and the cost was well over $120.00 for fluid and a filter.
Old Oct 12, 2004 | 10:30 AM
infidel's Avatar
Many of the diesel tranny rebuilders use and recommend Mercon or Dexron even when ATF +3 or +4 is recommended.
It won't harm your tranny but you might experience jerkier shifts, if it bothers you add a bottle of Lube-Gard.
http://www.lubegard.com/automotive/trans_atf_hfm.html
Old Oct 12, 2004 | 10:56 AM
Toby's Avatar
Thanks guys he might have said Mercon and I misunderstood what he said. So it's alright to go ahead and use it then?
Toby
Pig
23
Jun 4, 2010 01:01 PM
Mslaughter
Aug 24, 2006 06:44 PM
dieselfan
Aug 5, 2006 10:44 PM
Pig
Mar 13, 2006 09:12 PM
98rammer
Nov 4, 2002 06:23 AM
