Atf+3??
Old Jan 12, 2005 | 10:06 AM
BPD239's Avatar
Atf+3??
I have had some problems with the transmission in the truck....due to an improper gauge install, and now I have to change the fluid in the tranny. I have read here about how Dodge ATF+4 is the way to go. I went to the dealer and tried to buy 2 gallons of it and they told me not to use it. The dealer said that if I wanted to add to the current fluid level I should buy a quart of ATF+4. If I was changing the filter and fluid, I should use ATF+3.
Any comments or suggestions???
I don't want a problem down the road.
Old Jan 12, 2005 | 11:26 AM
Dodgezilla's Avatar
Your truck came from the factory with ATF+4! Why would the guy tell you to put ATF+3 in there? That will void your warranty!!!!!
Get the ATF+4.....................
Old Jan 12, 2005 | 11:30 AM
infidel's Avatar
and don't go back to that dealer. Sounds like they're wanting you to void your warranty.
Pig
23
Jun 4, 2010 01:01 PM
Mslaughter
Aug 24, 2006 06:44 PM
dieselfan
Aug 5, 2006 10:44 PM
Pig
Mar 13, 2006 09:12 PM
98rammer
Nov 4, 2002 06:23 AM
