apps symptoms??
Old Feb 26, 2007 | 04:38 AM
wadecool's Avatar
apps symptoms??
So far I haven't seen anyone else have these apps symptoms..... When I'm driving long stretches, as I'm getting off the interstate I'll slip it outta gear and coast down the exit ramp. Then the check engine light comes on and I have no throttle, only idle. I just pull into a gas station & do the apps reset procedure. After I finish that I clear the codes with my superchips programmer, and the check engine light goes off. What do you guys think?
Old Feb 26, 2007 | 04:47 AM
TorqueJunkie's Avatar
Mine would dead pedal after long stints using the cruise control, it went away after the dealership warrentied the VP. I didn't get any lights though, it would just dead pedal for a second and then come back to me. After the new VP it has done exactly what you descibed once. I did the APPS reset and the problem hasn't come back, and that has been months ago.
I would guess you have a failing APPS...
Old Feb 26, 2007 | 08:01 AM
wadecool's Avatar
I still have 1000 miles til I get home and will be able to fix it. Do you think I'll be ok to get home?
Old Feb 26, 2007 | 09:06 AM
FD5's Avatar
FD5
What is APPS and how do you reset it?
Old Feb 26, 2007 | 12:18 PM
chadwick's Avatar
i just replaced mine and every now and then it would give me the dead pedel. At idle in park or neutral sitting still my RPMs would jump around. Since replacing it all that is gone
Old Feb 26, 2007 | 12:34 PM
NoChrome's Avatar
accelerator pedal position sensor. Im lost as to how one is reset.
Old Feb 26, 2007 | 03:09 PM
Yes you should be fine to get home as long as the part doesn't totally fail on you.
Old Feb 26, 2007 | 03:11 PM
You can find the reset procedures here...
https://www.dieseltruckresource.com/...n&onlynewfaq=1
And check and adjust the voltage output with these...
efrantz
Nov 3, 2007 11:51 PM
Sean S
Jul 7, 2007 11:23 PM
spacely
Apr 4, 2004 09:35 PM
Rammer64
Dec 11, 2002 10:47 PM
1ST GEN.
Oct 19, 2002 08:45 AM
