Another codes problem
Old Apr 2, 2007 | 03:09 PM
quiettruckssuck's Avatar
Question Another codes problem
Hey guys, I know I'm new here so please forgive me if I ask a common question.
First, here's the issue. My truck has the check engine light lit. About half the time while driving (50 mile commute) my tach will just drop out. Falls to zero. When this happens, I loose probably half my horsepower. My mechanic said my truck gave these codes in three tests. I showed different codes on every test.
1st run p0219
2nd run p0341
3rd run p1693 and p1698
I think I need a new PCM, my mechanic isn't sure but he asked I look around on the web and find out what I can. He's a friend of mine that I trust, so he's wants me to help diagnose the problem to save on shop time.
Any thoughts? Thanks!
Old Apr 2, 2007 | 06:50 PM
vzdude's Avatar
DTR's 'Go to Guy'
Look here -> https://www.dieseltruckresource.com/...n&onlynewfaq=1
Sounds like a cam or crank sensor going out.
Old Apr 3, 2007 | 09:51 AM
DieselLady's Avatar
1st run p0219
2nd run p0341
This is a typical symptom of a Crank position sensor going south. It is around $75 from the dealer and is located on the block just behind the starter. Not a big deal to change but you do need to pull the starter to access it. When mine went, it threw codes off and on for about a month before the tach finally dropped to 0 and then came back. I would just replace it first and I'll bet the problem will go away. Computers do go bad but not that often and cost a lot more money. The 1693 codes are companion codes to let the tech know that there is a code set in the pcm.
Let us know if this solves the problem.
Old Apr 3, 2007 | 02:32 PM
I ordered the sensor today and I will post back after the swap. Thanks for the help!
Rumble Guts
Old Apr 10, 2007 | 02:31 PM
Ok, here's a real head scratcher. I ordered a new crankshaft position sensor (CKP) for my truck. I printed out the detailed instructions from DTR (see below)
http://www.dodge-diesel.org/articles/cps/ckp.htm
We put my truck up on the lift, and where there SHOULD be a CKP, there is a steel plate with one bolt. The specs say I should have a sensor there, but I don't have one there, just a plate and bolt. So now I'm wondering, where the heck is the CKP for my 2001, 2500 4x4 quad cab? It's not where it's supposed to be (according to the literature). The sensor that NAPA sold me is indentical to what cattle hauler has described in his post, but there's nothing behind my starter.
Any good ideas? Heck, I'll even settle for some bad ideas at this point.
Thanks.
Old Apr 10, 2007 | 04:31 PM
DieselLady's Avatar
Thanks.
Well theres your problem, somebody stole it.
Old Apr 10, 2007 | 05:23 PM
phox_mulder's Avatar
I guess that answers the question as to what year they went from a dual sensor system to just the one sensor.
The other sensor in question is somewhere around the VP44 (I think).
Crank sensor was down underneath by the starter, cam sensor must be up top?
phox
Old Apr 10, 2007 | 06:56 PM
tornado's Avatar
it is down under the vp 44 on the gearhousing. it runs of the cam.
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
