Alternator or voltage regulator problem
Old May 1, 2006 | 05:42 PM
emcconne's Avatar
I have a '91 W250 4x4 (see sig). I recently replaced both the alternator and voltage regulator in search of a solution to an electrical problem I'm having, however now when I measure the voltage across the battery with a voltmeter at runtime I'm seeing 16-18V. This never happened in the past, I usually had a reading from 13-15V. What could be happening? Won't this cook my battery?
Old May 1, 2006 | 08:00 PM
RCW's Avatar
RCW
You should see 14-15 volts with a good electrical system. The high reading is indicative of either sulphated batter(ies), or a bad cable connection at one or more ends of either the ground or positive battery cables.
A common problem is the terminal end corroding between the wire and the terminal inside the the lead where you cannot see the corrosion.
Old May 1, 2006 | 11:40 PM
Spooler's Avatar
Yeap you got a problem. Don't drive it or you will start to blow fuses and burn up motors. It is probably the regulator. I had to fix a truck one time that the internal regulator went out(customers). Needless to say, it was expensive. You should be around 13.8v to 14.5v. Check your grounds also.
imbodie
21
Jan 8, 2024 08:49 AM
chariotdriver
Jul 2, 2010 05:22 PM
Common
Jan 11, 2007 09:05 PM
darrenG
Oct 26, 2005 10:39 AM
Rauschbo
Feb 2, 2005 07:53 PM
