alternator problem
Old Sep 11, 2006 | 08:50 PM
jnnmillwood's Avatar
alternator problem
I have a 1995 3500 dually 12 valve. It seem to take a long time befor it starts charging, some times the check engine light comes on. My frist diesel can someone help.
Old Sep 11, 2006 | 09:11 PM
phox_mulder's Avatar
What's the temperature been when you've noticed this?
It is fall, and the nights are getting colder, and thus the cold morning starts.
Takes a while for the heater grid to stop needing juice, so the alternator guage will sit low for a while.
phox
Old Sep 11, 2006 | 09:24 PM
It does it when it's hot or cold.
Old Sep 11, 2006 | 10:30 PM
XLR8R's Avatar
Bad charging diode?
Old Sep 11, 2006 | 10:33 PM
dslpower's Avatar
Does the tach work properly when the alt is acting up?? The computer controls power to alt to make it start chargeing. Do the key on/off/on/off/leave on trick and count the flashes of the check engine light.
There will be at least a code 55 which means self test is done. See what it says and go from there. But probably just the brushes getting worn in the alt. You can always take it off and have it tested at the parts place.
5.9Excursion
Mar 13, 2008 07:08 AM
bigredbrick
Nov 8, 2006 12:18 PM
emcconne
May 1, 2006 11:40 PM
Ron
Jan 24, 2005 09:29 AM
