adjusting trans bands, need location of ID tag
Old Oct 1, 2006 | 08:19 PM
2500's Avatar
need help in finding ID for 12v auto transmission 97 CTD. adjusting bands, got tranny apart.
spec's are different for different models. Haynes states one things, all the tech articles state different spec's depending upon tranny.
need to get my tranny back to gethere.
thanks in advance!!!
Old Oct 1, 2006 | 10:09 PM
2500's Avatar
found a tag under hood with ID "DGP" 4sp transmission type.
which matches with 47RE , so I went with 47RE spec's below.
Haynes spec's is either wrong or spec's below is wrong.
did a google search and found:
3B7KF23D4VM550002=
VIP Summary Information
Body Style: BR7L32 Build Date: January 31, 1997 Hour: 17
Book: R Carline: T
Color 1: PGF - Emerald Green Pearl Coat
Color 2: QGF - Emerald Green Pearl Coat
Engine: ETB - Engine- 5.9L I6 Cummins Turbo Diesel
Transmission: DGP - Transmission - 4-Spd. Automatic,47RE
Sale Type: 1 - DIRECT RETAIL Last Odometer: 66,972 Kilometers on
October 23, 2001
# 1997 [From: "Paul R. Haller" To: DiRT]
* Front Band
o 46RE - tighten screw to 8N.m or 72 inch pounds, back off 2 7/8 turns
o 47RE - tighten screw to 8N.m or 72 inch pounds, , back off 1 7/8 turns
* Rear band
o 46RE - tighten screw to 8N.m or 72 inch pounds, back off 2 turns
o 47RE - tighten screw to 8N.m or 72 inch pounds, back off 3 turns
* The adjustment screw inside the case is a square head bolt. You will need a special 1/4 square head socket to fit your torque wrench.
Old Oct 2, 2006 | 12:03 AM
XLR8R's Avatar
I ran into the same problem on my '98 Ram; I followed the factory service manual instead of the other sources.
onehitwonder53
Apr 11, 2015 07:09 PM
59FORD
Apr 7, 2006 12:28 AM
serious
Mar 8, 2006 04:03 PM
Ridiculous
Jan 25, 2006 08:13 PM
03racecarhauler
14
Feb 22, 2004 11:05 PM
