AC Help
Old Jun 25, 2005 | 09:33 AM
popeyesides's Avatar
AC Help
Howdy,my AC stops blowing cold above 1800 rpm.I have 90,000Miles on It ,I also have a Horton fan clutch,any idea what went bad.thanks......
Old Jun 25, 2005 | 11:46 PM
12valve@heart's Avatar
Can you tell if the compressor is cutting out/shutting off at 1800RPM? If so, my first guess would be that you may be a bit low on freon and that at 1800RPM, the low side pressure is dropping down enough to cause the low pressure safety to cut out. Get a set of AC gauges put on it to see if you have a full charge.
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
