ABS and Brake lights after Master Cylinder and caliper replacement
Old Nov 5, 2008 | 09:16 PM
cappykd's Avatar
Unhappy ABS and Brake lights after Master Cylinder and caliper replacement
Help
https://www.dieseltruckresource.com/...d.php?t=222471
Old Nov 6, 2008 | 07:57 AM
high bid's Avatar
probably need to bleed the system. I experienced the same issue.
Old Nov 6, 2008 | 09:25 AM
cappykd's Avatar
Thanks for the reply. so you are saying to rebleed.
Old Nov 7, 2008 | 07:31 AM
high bid's Avatar
yes. From what I've experienced when changing any of the brake components it's best to bleed all the air, etc from the lines. For a short trick try leaving the cap off the master cyclinder and pumping the break pedal a bunch...sometimes the air will come back out this way; if not then you'll have to open the bleeder valves at the calipers.
Gen414
May 7, 2009 11:08 AM
polaris800sp
Nov 13, 2008 05:35 PM
cgmorgan06
Nov 15, 2007 04:02 PM
