abs and brake light
Old Dec 31, 2002 | 10:24 AM
mopwr2002's Avatar
abs and brake light
??? not sure why these 2 lights are on, the brakes work fine I was told it could be the sensor on top of the rear dif. any ideas on why the ABS and Brake light are on would be appreciated. 1997 ram3500 4x4 automatic dually
Old Dec 31, 2002 | 10:28 AM
Alan_Reagan's Avatar
Re:abs and brake light
Sometimes the sensor is loose in the housing, the connector might be dirty or the sensor is bad. It will cause the lights to come on.
Old Dec 31, 2002 | 10:34 AM
TPilaske's Avatar
low brake fluid? Brake light came on on my Ranger 'cause the fluid was low (pads were worn down quite a bit too!) ;D<br><br>Tony
Old Feb 8, 2003 | 07:08 PM
awmasparky's Avatar
Great site, lots of info.<br>I have a problem with the same lights being on, and the check engine light. My speedometer is not working either ???. I replace the speed sensor today, no luck. Going to check for fault codes later. Please post what finally works for you.
fitzydog
21
Oct 11, 2017 12:09 PM
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
polaris800sp
Apr 7, 2009 10:08 AM
mr T
Feb 24, 2007 06:42 AM
