'99 24 valve won't start
Truck has been turning over several times before starting, now won't start,
I changed the bango fitting on the side of the vp, but same thing, I cracked one of the lines in the first cylinder and fuel is spurting out as you turn it over.
Just checked the codes got PO238, P1689, PO236
P1689 No Communication Between ECM and Injection Pump Module.
Data link circuit failure between ECM and fuel injection.
P0236 Map Sensor Too High Too Long.
Problem detected in turbocharger wastegate.
P0238 Map Sensor Voltage Too High.
MAP sensor voltage input above the maximum acceptable voltage.
Machinos
Mar 16, 2008 01:34 AM
