96 5.9 Wont shutoff thru ignition
Old Jul 29, 2010 | 06:45 PM
technolackey's Avatar
i accidentally did a rolling jumpstart with my truck with ignition off, and now my truxk wont shutoff.. Tried pulling the relay and swapping with ASD relay, didnt help. only thing that works i pull fuelpump fuse. Any ideas cause i cant be stalling my truck everywhere i go or jumpin out to pull the fuse... thats just nuts
Old Aug 1, 2010 | 07:47 PM
Dojman's Avatar
I don't know for sure that I know what you're saying? If you have your solenoid wired up, then just unwire it. If you don't have your solenoid wired up, how did it get fuel to run with the key off?
Old Aug 10, 2010 | 05:23 PM
If i started my truck with the key, and then turned the key off and pulled it out my truck stayed running. I think the jump start surged a resistor or relay, cause after leaving my truck off over night, it worked fine again... moral of the story, dont roll yer truck slowly, turn it off, and leave it in gear when u let go of the clutch... lol
Old Aug 10, 2010 | 08:55 PM
rockcrawler304's Avatar
I'm still completely confused as to how you roll started your truck with the ignition off.
Anyways, glad it is back to normal.
Old Aug 11, 2010 | 09:59 AM
infidel's Avatar
Me too.
It is totally impossible for a 12 valve to start unless the shutdown solenoid is pulled up with juice from an on key.
mullishacrew
May 29, 2008 12:13 PM
Dufrain
Nov 9, 2006 08:18 PM
ChrisPickup
May 7, 2006 09:49 AM
chuck3
Mar 15, 2003 06:45 PM
Dieseldude4x4
Nov 23, 2002 10:16 PM
