truck is "jumping" not sure whats causing it
Old Aug 2, 2010 | 08:46 PM
BrysonCowboy01's Avatar
I have been driving around town going about 50-55 sometimes faster and my truck will suddenly jump, like the throttle is gone then suddenly back on, not sure what is causing it. I have been told it might be my injector pump going out, or that i need my shift points changed, even that its a throttle position sensor. If you have any ideas on what it could be please let me know
Old Aug 2, 2010 | 09:05 PM
Tacomaman87's Avatar
fill out your sig so we know what we are dealing with for a truck. lots of options but you will have better luck with responses if your sig is filled out
Old Aug 2, 2010 | 09:09 PM
Onemoparnut's Avatar
Hard to say with out knowing anything at all about the truck. If it ia a mechanical truck check the fuel shutdown selonoid. My truck did the same thing and the wire had a bad connection.
Old Aug 2, 2010 | 09:31 PM
rattlerbob5.9's Avatar
Sounds like a case of dead pedal from a 24 valve truck but that is only a guess until you can tell us more specific what year and model truck you have along with any modifications it has on it.
Old Aug 2, 2010 | 09:37 PM
His profile says 99 2500
Old Aug 10, 2010 | 04:14 PM
its a 99 2500 4x4, and all i have on it is a k&n 57 series cold air intake and a 5 inch turbo back exhaust strait piped, my rpm's are spiking from about 1300 to about 2100-2200 and it will go back and forth doing that constantly anywhere from 50 to 75 mph, any help will be aprreciated i thought i had my sig filled out, my bad y'all
Old Aug 12, 2010 | 03:47 PM
mini14's Avatar
mine was doing the exact same thing 2 days ago pulled a 0236 code, changed my map sensor all is well again, if u get codes especially 0216 be prepared $$.
FirstGen1991
Dec 22, 2012 04:24 PM
MK2Bob
Feb 15, 2009 06:50 PM
bch4x4cop
Dec 6, 2008 05:13 PM
Turbo-Dodge
Aug 2, 2008 12:06 PM
John Rodriguez
Sep 28, 2005 11:46 AM
