6.7 wont start
Old Jun 8, 2008 | 02:54 PM
jbworm20's Avatar
6.7 wont start
My brother in law is in a bind hes gotta haul a load with his truck and he was installing an electric ice chest in the truck and wired it up to a hot wire that was only hot when the key was on. ice chest works fine now the truck wont start any help would be great . Need to get on the road. thanks worm
Old Jun 8, 2008 | 03:37 PM
Purplezr2's Avatar
Has he checked his fuse.
Old Jun 8, 2008 | 09:28 PM
jbworm20's Avatar
All fuses are intact and I do not know of any relays etc. that might be present.
Old Jun 9, 2008 | 08:17 AM
jbworm20's Avatar
I have got ahold of a dealership and they said that he may have shorted out the tippin module I have never heard of that. anyways does anyone know what that is.
Old Jun 9, 2008 | 08:35 AM
John Faughn's Avatar
1st [ but too late ] , is find out what load the accessory is going to pull [ amps ] , then run pos. wire [ rated for that load ] to battery pos. with a fuse or breaker [ rated for the load ] .
As for tippin module , I have done a couple searches , nothing , not sure if spelling is off or it does not exist .
Have you tried disconnecting the cooler ?
Find out what wire was used ?
There are fuses under hood & dash , then fuse able links at batteries also .
Old Jun 9, 2008 | 08:37 AM
jbworm20's Avatar
where are the fuses under dash i looked all over for the ones under the dash?
Old Jun 9, 2008 | 10:51 AM
AggieJustin's Avatar
I believe the dealer was referring to the TIPM (Totally Integrated Power Module).
There were a number of posts about this when Dodge switched over to this setup (in '06 I think). Basically instead of routing things through fuses, there was a power module that controlled the flow and would trip if the load was exceeded. Then the dealer had to reset the module.
A lot of people weren't happy because the trailer lights were routed through this module and anytime you latched onto a trailer with bad wiring, you risked tripping the module.
Old Jun 9, 2008 | 02:23 PM
BroncoHound's Avatar
The TIPM gets my vote as well. I think he is going to need to have the dealer reset it. Also, on the 06+ trucks with TIPM, there is no fusebox in the cab. Just the one on the driver's side engine compartment, by the driver's side battery.
rustydeeretech
Jun 16, 2010 09:41 AM
CoolumConst
Oct 11, 2008 10:00 PM
Stroked-Z
Oct 4, 2008 11:28 AM
qcstunter
Jan 9, 2007 04:10 PM
Desert Diesel
Dec 5, 2002 08:53 PM
