4x4 and vent control went out
Old Sep 26, 2006 | 04:58 PM
dodge2001's Avatar
Question 4x4 and vent control went out
ok, i figured out that the 4x4 and vents run off of vaccum. where does the truck make it's vaccum. i'm used to gassers and manual hubs so this has never been an issue before. also where would the fuse/relay be to control it.
on a side note i killed third gear the same day this other junk went out. third gear was worth it since i got a 6.0 power smoke redlight to redlight with his little Banks badges all over it. so i guess it's time to put a 6-speed in the truck.
Old Sep 26, 2006 | 05:15 PM
Gunrunner's Avatar
ther is a vacuum pump attached to your power steering pump
Old Sep 26, 2006 | 05:18 PM
dodge2001's Avatar
is there anything electronic going to or from that pump setup or a central vacum block where the lines branch off to different acc.
Old Sep 26, 2006 | 05:20 PM
Gunrunner's Avatar
couldnt tell you on that, but I have seen where brake fluid has dripped onto the vac hose for the axle disconect and deteriorated the hose resulting in no 4x4------someone more familiear with your truck will chime in soon
Old Sep 26, 2006 | 05:30 PM
CSAGrey1's Avatar
Right in the middle of your firewall (maybe to the right of the head a tad) is a vacumme T. Check to make sure it hasn't come unhooked. If it is still connected tracing everything from this point is a breeze. I had this same exact problem just a few weeks ago and found that that line was disconnected down below.
Old Sep 26, 2006 | 05:44 PM
dodge2001's Avatar
thanks for the help, tomarrow when i get home i'll check it out. i had no clue as to how diesel's make vacum. hopefully it's just a dag'on loose hose
Old Sep 27, 2006 | 09:12 AM
Scramblinman's Avatar
It's also pretty common for battery acid to cause the vacuum line to the cruise control servo under the driver's side battery to fail and for the vacuum line that runs along the top of the firewall and then into the cab for the HVAC system to come lose, drop onto the exhaust, melt, and fail.
Old Sep 27, 2006 | 09:26 AM
infidel's Avatar
Easy way to tell if you have a vacuum leak is to disconnect a vacuum line after the truck sits for a few hours. If you don't hear a hiss you have a leak. Most rigs will hold a vacuum and hiss when disconnected even after sitting for several days.
bigfoot
Jan 1, 2010 02:22 PM
97catintenn
Aug 7, 2009 08:23 PM
VikingDiesel
Aug 12, 2007 10:10 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
drew03
76
Feb 6, 2006 07:57 AM
