47re problem
Old Mar 9, 2006 | 09:36 PM
projectRam's Avatar
47re problem
i have a problem with my tranny if you manualy shift it. it hits 1-2-3 and thats it no 4th and no lockup in full auto in drive it starts out in 2nd any ideas
Old Mar 9, 2006 | 09:52 PM
mooseman's Avatar
Just a guess but sounds like limp mode. Have you checked for codes?
Mooseman
Old Mar 9, 2006 | 10:10 PM
DODGE4X4's Avatar
When mine did that it was a sensor. What year is your truck???
Old Mar 9, 2006 | 10:11 PM
chop342's Avatar
From: Climax, MI (between battlecreek and kalamazoo)
PM: DHAWK, he knows his stuff or call him, or check him out here, he is a trans guy for courtesy dodge in grandville MI and really knows torqueflite. http://www.htstransmissions.com/
Old Mar 9, 2006 | 11:26 PM
projectRam's Avatar
truck is 98-24 v no codes seen sensor for speed changed no difference tranny does not slip
Old Mar 10, 2006 | 07:26 PM
Tiny Ram's Avatar
Check the governor pressure transducer, that will cause the 2nd gear starts. IF you lost OD and lockup it's a failed solenoid/relay, they are both solenoid controlled on the same little block of the VB.
thehemikid
Feb 25, 2021 12:45 PM
Munchies
Oct 19, 2006 06:09 AM
Silverjay
Oct 16, 2005 08:28 AM
Silverjay
Oct 12, 2005 07:59 PM
ipsduc
Sep 24, 2003 08:28 PM
