3rd gen. dead
Old Aug 22, 2006 | 09:15 AM
DDR1951's Avatar
3rd gen. dead
I was driving to work this morning about 65mph and when i started to slow down to make a turn my truck died, no sputtering or surging, instant shut off. The truck will not start now, 44,000 miles on engine. Turning the key switch gave me these two codes P0113 and P0237 Intake air temp sensor voltage, and map sensor voltage. ANY IDEAS?
Old Aug 22, 2006 | 11:35 AM
Spooler's Avatar
Take the Edge box off and see if it will run. Box may have went bad.
Old Aug 22, 2006 | 12:01 PM
DDR1951's Avatar
i took it off first thing, it did not make a difference, it cranks but it will not crank over. im not much of a mechanic but it seems weird it just died.
Old Aug 22, 2006 | 06:22 PM
wcjp's Avatar
When is the last time the fuel filter was replaced? Fuel pressure?
Old Aug 22, 2006 | 07:01 PM
RCW's Avatar
RCW
Mileage and age is about right for failure of the fuel bypass valve on the common rail. Just stopping and no start is a typical symptom.
Old Aug 22, 2006 | 08:40 PM
DDR1951's Avatar
fuel filter is not very old im not sure of the mileage, but it is still pretty clean, i have no idea about the fuel pressure or how to even check it, Can i check it without it running.
Old Aug 22, 2006 | 08:43 PM
DDR1951's Avatar
would the fuel bypass valve on the common rail be a ctd warranty item you think. My understanding is that with 43,000 miles the only thing still under warranty is the ctd items, so if its a computer or something like that it is on me.
If anyone knows for sure that would be good information. I dont think i will be able to tow it to a shop until Friday, and if the warranty is not going to cover it id rather go somewhere other than the dealership.
Old Aug 22, 2006 | 09:28 PM
rich's Avatar
did you check your lift pump when mine whent out the truck died quicker then snot and would not run
Old Aug 22, 2006 | 10:03 PM
DDR1951's Avatar
i dont have any idea how to go about checking it, i did however take on of the tubing lines off that go into the engines and it shot a good stream of fuel. the fuel filter bowl will also fill back up if i drain it. i will do what ever i need to do to check anything i can.
Old Aug 22, 2006 | 10:16 PM
texaspower19's Avatar
try taking your negative cables off ur battery for a bit mine dies like that alot and the check engine light flashes real fast
Old Aug 23, 2006 | 10:26 AM
DDR1951's Avatar
i took them off to clean the post, but when i go home for lunch i will take them off and then try hooking them back up when i get back home tonight.
Old Aug 23, 2006 | 10:27 AM
DDR1951's Avatar
Talking
Thanks All Of Yall For The Help So Far
Old Aug 23, 2006 | 09:28 PM
DDR1951's Avatar
Chrysler Road Service hauled me in and the dodge house will be calling me in the morning. WISH ME LUCK
Old Aug 23, 2006 | 09:39 PM
donhov's Avatar
Just remember, if it is engine it is covered by Cummins warranty. 5years 100K no deductable, 7yr 100k $100 deductable. Covered items include block, crank, pistons fuel pump, injectors and many other items I don't remember all, check your warranty book or call DC. Dealer tried to stiff me the $100 for a bad injector but I called Dodge Customer Care and had them explain it to him, he then put it into his compouter and guess what, no charge came up on screen. I hate dealers, he kept pointing to his warranty book that showed less than 84 months 100K miles then it would be $100 and he wouldn't even look at the line above it that said under 60 months 100K no charge.
Old Aug 23, 2006 | 09:45 PM
XLR8R's Avatar
Wow!
Less than 2 years & 40 something K miles is the expected service life of the fuel bypass rail on an '05?
