2004 P0628 Cranks no start - how to bypass lift pump?
Old Jun 28, 2009 | 09:03 AM
Mulekick's Avatar
Lift pump is mounted on the filter.
Need to get truck running. No stores have part nearby.
It looks like all i need to do is connect the fuel pump inlet to the hose coming out of the filter housing and install a inline generic filter?
Will that get me 200 miles to the nearest dodge dealer? Truck may still be under emissions warranty.
Thanks
Old Jun 28, 2009 | 01:23 PM
Mulekick's Avatar
fixed
Old Jun 28, 2009 | 09:50 PM
Miles PH's Avatar
Tell us how you fix her. Pleas having same problem with 04
Old Jun 28, 2009 | 11:28 PM
Mulekick's Avatar
A foot of 3/8 inch hose, 3/8 to 1/4 hose barb fitting, 6 inches of 1/4 hose, generic fram metal fuel filter, and hose clamps. I also bought some caps to cover the "in" and "out" of the stock fuel filter.
First disconnect the electrical connector from the lift pump!
I disconnected the fuel hose from the lift pump. Installed inline fuel filter here. Then a section of 3/8 hose.
Then I disconnected the 5/16th hose between the injection pump assembly to the stock filter and replaced with 6 inches of 1/4 and the 1/4 to 3/8 hose barb.
Basically I bypassed the stock filter with an inline filter.
Once everything was connected and zip tied out of danger I loosened injector #1 and cranked the engine 4 times for 5 seconds each time till all the air came out of the injector.
Tightened the injector bolt and drove 200 miles with 3000# trailer back home. The truck drove the same (level #2) but I didn't get on it in its weakened state
From reading the posts here I think I'll go with an aftermarket upgraded transfer pump.
Old Jun 28, 2009 | 11:36 PM
Mulekick's Avatar
Oh the truck has 62K miles on it and ran perfect till the pump quit (like a car when it runs out of gas).
Old Jun 28, 2009 | 11:52 PM
Totallyrad's Avatar
Hopefully your build date is late enough to get in under the wire on the emissions warranty. If you can the cost to you should be $-0-.
Garlocker
Jun 26, 2014 09:27 PM
stange
Jun 22, 2010 11:08 AM
slubik
Feb 4, 2010 05:28 PM
ctd4stan
Mar 19, 2009 08:35 PM
screaminbanana
Aug 25, 2005 09:30 AM
