2004 fuel problem
Old Nov 27, 2007 | 08:11 AM
ralph540's Avatar
Angry 2004 fuel problem
have 2004 3500 4x4 dually 5.9 117000 miles all of a sudden stalls wont start has new fuel filter, if you let is set for a while it will restart after cranking a long time, also have code p0628 help
Old Nov 27, 2007 | 08:29 AM
dssimecek's Avatar
P0628 Fuel pump relay circuit low, or fuel lift pump control circuit low.
Hope this helps, not sure what the fix is.
Old Nov 27, 2007 | 09:47 AM
dodgezilla04's Avatar
the factory lift pump on an 04 is mounted to the rear of the fuel filter housing. in a hot and vibrating environment, they are known for failing. i am surprised that yours lasted 117000 miles, pretty good. time for an aftermarket pump that is relocated to a framerail near the tank.
fass, bd, glacier, etc.
all much better than the factory pump and location
gsdog1
Aug 3, 2004 10:01 PM
drno
Jun 18, 2004 06:57 PM
bmallen
Feb 29, 2004 10:30 PM
shortround
Feb 28, 2004 12:06 PM
Huntindad
Feb 9, 2004 06:45 AM
