2003 engine looping at idle
Old Nov 8, 2006 | 09:29 PM
finally got one's Avatar
i have a 2003 dodge ram 3500 with 198,000 miles on it. i have only had it a month now and it is starting to loop at idol. it started to get bad when there was about 1/8 tank of gas left. i changed the fuel filter and filled it up. it ran fine for awhile. tonight it started again this time with 1/2 tank. HAYNES troubleshooting says anything from vacume leaks to injectors to fuel pump. does anyone have any ideas? the truck seams to run ok once you get rolling it just loops at idol, sometimes idols high. any help would be great, i hope i didn't get taken.
Old Nov 8, 2006 | 09:33 PM
XLR8R's Avatar
A fuel pump gauge would sure help you troubleshoot...
Old Nov 8, 2006 | 09:43 PM
bulabula's Avatar
Hey, welcome aboard. These are good trucks, but sometimes they like to mess with you, like loping at idle.
Is it throwing any codes? There's a way to do it by turning your key on and off a couple of times while pressing the tripmeter **** or something like that - check your owners manual on how to do it (I haven't done it in a long time). If there are any codes, they will be displayed in the odometer.
Could be something as simple as lousy fuel (not gas...) too. Any idea of who the previous owner was, did they run any diesel fuel additives (DFA) in it? Are you? With 198k on it, there's been some fuel flowing through it. I wonder if its worth checking/changing that new fuel filter; maybe there is a lot of gunk in the fuel/fuel system - its been known to happen.
Hang in there, like I said, these are good trucks.
Old Nov 8, 2006 | 09:47 PM
i've seen alot about the pressure gauges. how much do they run and how hard are they to install? as for any additives i'm not running any and i dought it was before it was owned by a local company that hauls rental equipment.
Old Nov 8, 2006 | 09:49 PM
bulabula's Avatar
Go check for codes - its easy and free while sitting in the driveway.
so far i really like the truck tonight i loaded 28 sheets of 7/13 osb and can't really tell i put anything in the bed. i'm just woried about injectors i was told thats about $1500 for parts only
Old Nov 8, 2006 | 09:52 PM
the only code it has shown was a p0341 camshaft potsion (cmp) sensor signal that came on when my wife almost stalled it and when i first changed the FUEL filter
Old Nov 9, 2006 | 08:57 AM
J BODY's Avatar
With the DRB I would monitor fuel rail setpoint and actual psi. There is also a test for the fuel contol solenoid which I would check as that is most likely the cause.
Old Nov 16, 2006 | 06:57 PM
i have no idea what this last post means? i looked for a fuel control solenoid and cannot find anything like it in the HAYNES. does anyone know where to get a fuel pressure gauge and how to install one?
Old Oct 31, 2008 | 08:20 AM
1stgenatheart's Avatar
Did anyone figure out what the problem was here?
Idaho Guy
33
Jan 6, 2008 09:27 PM
DodePops
Aug 17, 2004 08:55 PM
DodePops
Jul 27, 2004 06:53 PM
shortround
Aug 22, 2003 02:50 PM
