2003 dodge BAD Diesel Leack
Old Apr 12, 2010 | 09:16 AM
canadakonrad's Avatar
Exclamation 2003 dodge BAD Diesel Leack
Hi guys, i have a 2003 5.9 cummins diesel 1ton dually 4x4 with 255.000km, im leaking diesel, badly, from somewhere behind the fuel filter i think though, not sure! i cant figure it out!? lift pump? what could it be? thanks konrad
Old Apr 12, 2010 | 09:18 AM
roughly 160.000 miles...
Old Apr 12, 2010 | 09:57 AM
Mexstan's Avatar
Have you changed the fuel filter recently? If so, could the gasket have been pinched?
Old Apr 12, 2010 | 07:24 PM
wafflehouse's Avatar
Take the fuel filter lid off and check the gasket around the lip. Also check the cover for cracks, it's plastic and can break if over tightened.
Old Apr 12, 2010 | 07:45 PM
Kowalski's Avatar
Check the return line banjo bolt on the back side of filter houseing. Might want to check the water drain valve on the bottom of the filter houseing. Also take a look at the fuel line on the back of the filter houseing that comes from the lift pump.
Old Apr 12, 2010 | 08:19 PM
03RAMBUNCTIOUS's Avatar
I watch wind blow...
My number 5 injector line on the rail started leaking about two years back. tightened it up and it was fine after that.
Old Apr 14, 2010 | 09:47 AM
mark lagasse's Avatar
My 99 leaked from the heater wires that go into the filter
Old Apr 14, 2010 | 06:36 PM
MikeyB's Avatar
Check the #6 injector line coming from the common rail. It's a long run and unsupported and prone to cracking from vibrations. DO NOT stick your hand back there when the engine is running!! Can be deadly!! Use a piece of cardboard to check for leaks.
If it is the injector line order a new one and a support bracket used on the later models that mounts to the engine lift bolt.
MikeyB
joebishop23
Oct 29, 2007 10:19 AM
westexgt
18
Jun 19, 2007 10:30 PM
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
