2003 diesel won't start
Old Mar 21, 2006 | 01:01 PM
RCW's Avatar
RCW
The code is misleading, and is based on a standard set of definitions that are a one size fits all for a broad range of engines and vehicles. The low to which it refers has nothing to do with the true voltage to the lift pump, but is from the sensor in the injection system telling the system that the input fuel circuit feed pressure is insufficient. The same code is used in the gas engines, and there it means that the main in-tank fuel circuit pressure pump has failed.
Dodge Mack
Oct 12, 2009 05:38 PM
andywells
Mar 19, 2009 07:45 PM
frostedbarleypo
Sep 4, 2008 10:39 PM
bbrusseau
Mar 4, 2008 07:33 PM
steffan
Jan 9, 2007 09:24 AM
