2001 24v Engine "missing" then stalling out???
Old Sep 7, 2006 | 08:45 PM
XLR8R's Avatar
Originally Posted by blackdiesel
LOW fuel pressure is the problem with the in-tank. 8-9 psi at idle. on dad's with just a ez and 275's it would pull it down to 0 at wot. and that's not good. if the truck is stock it might have the volume to cool the IP, but most want to see that pressure needle closer to 15 than 5 psi
I thought the lift pumps mounted on the fuel filter housing only developed 4-5 psi... ?
Old Sep 7, 2006 | 09:28 PM
1st gen Hobie's Avatar
My boss has a 2001. Put in tank pump in. Now he thinks the ip is going. Missing and white smoke. Time to talk him into a gauge.
Old Sep 7, 2006 | 09:32 PM
XLR8R's Avatar
Why does low fuel pressure cause WHITE smoke?
Old Sep 7, 2006 | 09:47 PM
blackdiesel's Avatar
Registered
It don't, but a failing vp44 does
the stock lift pump by the fuel filter will put out 15 psi (when new), the in-tank pump is the low pressure pump, around 8 psi at idle
Old Sep 7, 2006 | 10:09 PM
XLR8R's Avatar
[QUOTE=blackdiesel;1120005]It don't, but a failing vp44 does[QUOTE]
OK - so why does a failing VP44 cause white smoke...
Huh - my buddy has an '04, he's got lower fuel pressure than my in-tank pump; his pressure hasn't really changed from new, from what I hear.
He's approaching 50K miles.
Old Sep 8, 2006 | 06:58 AM
Registered
intermitten white smoke is just one sign of a dieing vp44, I would say that it's low pressure on the HIGH side; Your buddy has a common rail, toldly diffarent fuel system, I thought we were talking 2nd gens here.
Old Sep 8, 2006 | 12:13 PM
XLR8R's Avatar
Sure - low HIGH pressure from a CP3 also makes white smoke... I know it's a fundamental question (dad - WHY does 2+2=4?), I was just curious why the smoke is white just because the engine is running (I imagine) way lean?
I'm used to:
black smoke - extra fuel
blue smoke - too much oil
white smoke - too much antifreeze or water
WOT haze - well-tuned diesel
green smoke - too much chili
Old Sep 8, 2006 | 03:11 PM
He said he paid around $500 for his. He couldn't rember the name of it. Does that sound like the normal in tank pump?
Old Sep 8, 2006 | 04:13 PM
Registered
that's what the dealer is charging, or more. you would be alot better off with a top of the line fass system for that much money
arcticcat12224
Dec 18, 2012 10:20 AM
jamie'sturbo
Apr 2, 2008 07:16 AM
5.9Excursion
Oct 29, 2007 12:12 PM
Ramtuff06
Jul 9, 2007 05:07 PM
wholden
Sep 6, 2004 08:39 PM
