2000 24 valve dead
Old Jun 23, 2008 | 03:54 PM
moparjet's Avatar
2000 24 valve dead
hello all,
well i am stumped..hit the gas and the truck took off then died..pulled over and restarted with engine light on...seemed to idle fine but when throttle applied acted like it was in fail safe...wouldnt rev up...limped it to a parking lot where it died all together and will not start...acts like a fuel pump problem..tries to start then dies.. got pcode 1693.... im thinking ip pump dead.. what do i do????? any help will be great..thanks
Old Jun 23, 2008 | 04:45 PM
John Faughn's Avatar
Fuel pressure test , if I remember , most say that 1693 is bad news , also , I've read posts stating that there are some electrical components in IP that are not hard to replace .
But testing to prove a part is bad is first , also , with a lot of reading , it seems like the LP can go bad , truck start with IP only , but shortens the life of the LP .
Old Jun 23, 2008 | 05:56 PM
wurkenman's Avatar
P1693 is just a companion code. It only means that there is a code stored in the ecm. Most likely there will be a code P0216 in there. This is the nasty one for the IP.
Old Jun 23, 2008 | 06:06 PM
cumminshakesit's Avatar
i was towing a 14' haulmark with my moms 01 CTD, it started acting the same way. i thought it was a fuel filter... changed it with no improvements. got a hold of a dealer, they said it was a factory recall for the lift pump. it came from the factory with a lift pump just above the starter (sucking fuel all the way from the tank through the filters, where the injection pump takes over). the recall replaced the block mounted pump with a sub pump in the tank. my mom never got the recall i think because she bought it in 03... anyway, dodge paid for everything, it's worth a call. good luck.
Old Jun 23, 2008 | 06:12 PM
moparjet's Avatar
thanks guys.. i guess i need to get the truck home first to do some testing.. how can i get the code out of the cummins ecm? can the electric part of the ip pump be replaced ? or do i need the whole pump... i do still have the lp pump above the starter..maybe i will make a call
Old Jun 23, 2008 | 10:25 PM
wurkenman's Avatar
Do not use this if you plan on any mods to your truck. Get a good after market pump ( check there are plenty) and you will have no future problems.
The in tank pumps require the tank to be dropped.
600 Megawatts
Mar 26, 2008 07:09 PM
Jvenne86
17
Mar 20, 2007 08:27 PM
vikingsven
Oct 29, 2006 08:28 PM
billygoat02
Dec 30, 2005 09:19 AM
DOMO
Dec 27, 2005 10:48 PM
