1999 2500 stuck in second gear
Old Aug 3, 2010 | 11:20 AM
mkozlows's Avatar
My son is at his work trying to get home. The auto shift linkage seems to be stuck apparently in second gear. he says he can only move the shifter a small amount as it is bound up pretty tightly. I had him pull apart one of the linkages to determine where the binding is. Shifter is ok, it is apparently bound down at the transmission. I am at a loss as to what this might be.
Can anyone offer any suggestions? I am 60 miles away from him at work, and would like to be able to get him home without towing the truck if possible. Thank you.
Old Aug 4, 2010 | 10:01 AM
oldblues's Avatar
hi
maby some more info would help ???
how and why was it put into 2nd gear as normaly a person would go from park to drive ??
any resent prob with trany , or work done to it that might be related ??
sometimes a park break ancor snapring gets broken disloged and james park rod , requiers vb removel to fix ?
see that there are no stones /sticks on top of trany linkage binding it ???
Old Aug 4, 2010 | 10:06 AM
mkozlows's Avatar
Originally Posted by oldblues
hi
I started another tread about this in 2nd gen as the rig is now at home. But the short story is that apparently a Band Anchor dropped out and wedged itself in between the valve body and the Rooster Comb.
birdboy
Dec 12, 2018 09:02 PM
Danwe
May 19, 2014 01:23 PM
banks twinram
13
Sep 28, 2010 09:25 AM
mw66nova
Apr 13, 2008 09:17 PM
Baja
Jan 29, 2008 08:17 PM
