12v starter issues
12v starter issues
I've got a '98 12 valve and its been running great. I drove it around all morning then parked it for a while. I went to start the truck and all I got out of the starter was a wizzzzing sound. I took the starter off and had it checked at the parts store, it worked fine. I know the part store can't put a load on the starter so I haven't ruled it out yet but I want to know what everyone else thinks.
btw, the starter is a remanufactured piece from cummins and the throw out bearing is going out if that makes any difference.
Thanks,
Kyle
Thanks,
Kyle
Check the FAQ page here.
http://www.fostertruck.com/dodge/
A wizzing sound sound maybe more like a stripped gear on the started or ring gear maybe though.
Thanks,
Kyle
Thanks,
Kyle
u can check for worn teeth..i guess u checked the starter and the teeth werent worn on that?....drop the access plate under the TC and turn the plate all the way around with a screw driver to check for bad teeth on the flex plate if it was just a mechanical whirring/grinding
Ok guys, I took the starter off and cleaned the contacts and plunger. They looked almost brand new already. I replaced all of the battery cables and the starter still wont turn the engine over. We tried to pull start the truck but couldnt get enough speed to start the truck. When we gave up I tried the key and the starter started the truck. Since then it has gone back to making a wizzing noise. I've tried turning the engine over by hand to move the flywheel incase there are any bad teeth on the flywheel but starter continues to make a wizzing noise. I am stumped and looking for suggestions.
This may sound stupid but when they checked to starter at the a/p store did the bendix push the starter gear ALL the way out?
Also I doubt this could even happen but what are the odds the ring gear could be slipping on the flywheel? If so when everything cools the ring gear might contract and "bite" again.
sure glad you got your problem figured out.
sticky bendix are a fairly common problem. very_seldom do ring gears slip. most of the time when they go, starter jammed on. destroying ring gear and starter.
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
