11.4 MPG?????
Old Dec 8, 2003 | 02:48 PM
Cumminsdude's Avatar
11.4 MPG?????
Ok guys, I filled up today and calculated my fuel mileage and it was 11.4. Normally its lke 12.5-13. I did add 360 lbs of sand in the back under my tonneau cover but why is my mileage so low? I have cleaned my IAT, changed the fuel filter, and reset the APPS and no improvement. My fuel pressure was good a few months ago. I am really getting sick and tired of paying all this when I should have better mileage. Anyone have any other ideas?
Old Dec 8, 2003 | 02:57 PM
Palmetto_kid's Avatar
Re:11.4 MPG?????
since you are in New York, I would attribute your mileage loss to winter blend fuel. There is a product at walmart called Powerservice that advertises to impove mileage while usinge winter blend.
with that said, I am also experiencing fuel mileage loss. My question is: In coastal Texas, do the pump stations switch to winter blend? I would think not becuase we have mild winters around here.
Old Dec 8, 2003 | 03:01 PM
Re:11.4 MPG?????
Yeah I have tried Power Service before with no luck in improvement. I'm lost for ideas.
Old Dec 8, 2003 | 03:09 PM
RCW's Avatar
RCW
Re:11.4 MPG?????
This must be in town, stop and go mileage. If that is the case, you are just a bit low. I would run some diesel injector cleaner through the system and see if that helps. Dirty or burned injectors really knock the mileage in a hurry. Winter fuel will also take it down a bit, if you can find some non-detergent 30 wt oil (do not use detergent oils), slip a couple quarts in the fuel tank, fill it with diesel, and your mileage will come back if it is just the fuel that is the problem.
Old Dec 8, 2003 | 04:04 PM
Rare1's Avatar
Re:11.4 MPG?????
Shell X100 straight 30 wt oil has the lowest ash content.
Dude, I can understand why 11.4 MPG would set you off, but why didn't 12.5? You must have other causes besides winter fuel. Heavy foot?
Old Dec 8, 2003 | 04:56 PM
Re:11.4 MPG?????
I do have a mildly heavy foot but I dont see how it would make it that low. Since I just fueled up I am going to not mash the throttle and just take it easy. Now I downshift to save my brakes and I let it idle quite a bit. Could that be the problem?
Old Dec 8, 2003 | 05:34 PM
scuzman00's Avatar
Re:11.4 MPG?????
Down shifting increases RPM's aabove 1800. This in turn will bring down fuel economy...Idling for long periods will cut mileage as well....850 rpm and tires going 0 rpm = poor economy to boot....
Gary
Old Dec 8, 2003 | 05:37 PM
amartinson's Avatar
Re:11.4 MPG?????
Is this out of the norm for you for winter mileage? I see a 2-3 mpg drop instantly when the pumps change to winter blend.
Old Dec 8, 2003 | 05:55 PM
Re:11.4 MPG?????
Ok I will stop downshifting and not let it idle as much.
I have no idea what the winer mileage is because I bought the truck in May but why would have have just put the winter fuel in their pumps now? I fill up there a lot and just noticed the decrease. Dont you think here in NY they would put the winter fuel in sooner than early december?
Would replacing my speed sensor help? I dont know if I have all the power I am supposed to because I havent driven many other diesels that we'rent bombed so I have nothing to compare mine to. It seems ok and has some power, I figured it would have a little more though.....I DONT KNOW WHAT I'M TALKING ABOUT THOUGH!
Old Dec 8, 2003 | 06:35 PM
Ram04's Avatar
Re:11.4 MPG?????
Do these things have o2 sensors on them? In my Dakota, a bad o2 sensor is known for producing bad performance and fuel ecomomy. Just a thought.
Randy
Old Dec 8, 2003 | 06:43 PM
Re:11.4 MPG?????
I believe in a diesel its called an IAT sensor but I may be wrong. If I am, please correct me. Thanks for the help Ram04.
Old Dec 8, 2003 | 09:10 PM
NAIL BENDER's Avatar
Re:11.4 MPG?????
Do you still have the stock tire size? If not, your mileage can be off from bigger tires. I also have a very heavy foot and at times my commute isn't very far away resulting in the same #'s. > When a job brings me further away my mileage goes up to about 16. I also downshift a lot and let my truck idle. These are the things we must deal with with an auto. :'(
Old Dec 8, 2003 | 09:14 PM
Re:11.4 MPG?????
I have 285's
Old Dec 8, 2003 | 09:21 PM
Re:11.4 MPG?????
With my 285's, I figure correction at 10%. This would increase your MPG by 1.14.
Old Dec 8, 2003 | 09:22 PM
Re:11.4 MPG?????
ok thanks, I'll try that next time.
