06 getting harder to start
Old Feb 17, 2011 | 09:47 AM
06 nightmare's Avatar
i have a 06 and i had gotten some bad fuel that had grit and water in it. I removed the tank and cleaned it out and cleaned the pump assembly and the screen. I also installed a new filter and cleaned the filter housing out as well. I refilled the filter housing with sea foam and a new filter and added lucas and sea foam to the new fuel. Its not smoking at all but it has a knock at part throttle and its getting harder to start. I tested the transfer pump and i have about 8-9 psi. Any ideas on what else to check. I dont really have the money to take to a dealer to have them check it, got laid off at Christmas so im on a tight budget. Thanks for any help
Old Feb 17, 2011 | 06:31 PM
sandking069's Avatar
Had the same problem with our 03 dodge, I ended up changing the fuel pump and changed the fuel filter at least six times. I cleaned the fuel filter housing every time I changed the fuel filter. Over all it cost $180 for the fuel pump and filters.
Old Feb 18, 2011 | 09:56 PM
J BODY's Avatar
I'd have an injector return flow test performed....... but if it fails that will blow your tight budget to pieces unfortunately.
chariotdriver
Jun 13, 2009 08:11 AM
MOAGGIE
Aug 22, 2008 08:12 PM
silverbullet02
Jan 29, 2006 10:04 PM
FireMarshalBill
Jan 9, 2005 05:59 PM
aarlucas
Jun 23, 2004 03:57 AM
