NV4500 getting harder to shift, help!
Old Jun 22, 2004 | 04:53 PM
aarlucas's Avatar
Angry NV4500 getting harder to shift, help!
Is there any standard trans experts out there? The NV 4500 in my 99 Ram 2500 CTD is getting harder to shift. Kind of snappy like is the best way to describe it. Snaps out of gear, with effort, and snaps into the next gear. The faster I go the harder it is. It also seems to be getting hard as time goes by. It used to be a very smooth and effortless operation.
I changed the special oil (23.00 per quart ) hoping it was just the old oil had given up. No change from that.
I was reading where it could be the pilot bearing going bad. But I hate to pull the trans just to find out it is not that.
Any ideas would be very helpful. Thanks
Old Jun 22, 2004 | 08:45 PM
Pa outlaw's Avatar
replace the clutch,if the clutch is going bad they get hard to shift,ive replaced a few that were that way and installed a clutch set up and they were fixed. they ussually where the preasure plate not the disc but i would start there,not sure how many miles are on yours so this is just a suggestion hope it helps you out,they are not to bad to change
Old Jun 23, 2004 | 03:57 AM
aarlucas's Avatar
PA,
I have 139K on the truck. To the best o my knowledge, it is the original set-up.
Thanks
edwinsmith
Mar 28, 2006 06:59 PM
silverbullet02
Jan 29, 2006 10:04 PM
Pooter
Jan 29, 2006 06:53 PM
EKUgrad
Jun 1, 2005 10:55 AM
FireMarshalBill
Jan 9, 2005 05:59 PM
