03 no start help!!!
Old Jun 19, 2007 | 07:36 PM
wldman32's Avatar
03 no start help!!!
drove truck to work today and every thing was ok. but when i I was letting it cool down it was missing ,then after work it will not start .it is not getting any fuel at all when it is turning over , i have good fuel pressure to the cp3 ,i un pluged all boxes and it still will not start .any ideas? codes are p0336,p0647(tst caused this ),p1652j1850(tihis one looks bad),p0602 thanks!!!!!!
Old Jun 19, 2007 | 09:22 PM
RCW's Avatar
RCW
The first thing to check on the 03 is the wire that leads from the AC sensor back around the engine. It rubs the insulation off and will ground out the fuel injection.
If that is not it, then check the fuel rail pressure relief valve. It gets leaky and will keep the rail from pressurizing. Symptoms are generally lousy performance, hard starting for some time, and a rough idle before it fails to start.
The A/C error (647) in combination with the ECM fueling calibration error (602) would lead me to check the A/C sensor first.
However, your problems could also be from corroded terminals at various places if some moron has been using a pressure washer on the engine. That is an absolute do not do on the Cummins diesels since 1998.5. If this has been the case correction can easily run hours and hours to diagnose and correct.
Old Jun 19, 2007 | 09:38 PM
wldman32's Avatar
man thanks alot for teh info !!! when you say ac sensor do you mean the wires from the compressor ?
Old Jun 21, 2007 | 09:18 PM
wldman32's Avatar
still broke down . it will start if i use ether but it misses real bad so i un-pluged the injectors two at a time (the only way you can do it ) and the miss did not change much when i un-pluged the middle injector harness .any ideas guys ? please help!!!!
Old Jun 21, 2007 | 11:02 PM
FMB's Avatar
FMB
Originally Posted by wldman32
...it will start if i use ether.
OMG, don't use ether! The ether flows right past your heating grid. They can get hot enough to ignite your ether and launch your intake manifold.... ouch.
Old Jun 22, 2007 | 09:26 PM
wldman32's Avatar
i know i un hooked the grid ,any help guys ? ideas?
Old Jun 22, 2007 | 11:05 PM
vzdude's Avatar
DTR's 'Go to Guy'
The wiring he was talking about is at the a/c pressure transducer. Here is a pic of it's location. Look at the wiring very closely. Between that and the crank sensor code, I think that's the direction I would look towards first. The j1850 circuit shorted to ground would be an indicator of the same problem.
Sarajaye
Nov 21, 2014 06:14 PM
TNDODGE
Sep 13, 2012 01:38 PM
CoolumConst
Oct 11, 2008 10:00 PM
502502
Nov 27, 2004 09:15 PM
eng208
Jul 14, 2004 06:21 PM
