03 hard starting
Old Aug 21, 2008 | 08:53 PM
2fastfountain's Avatar
Angry 03 hard starting
I have a 03 2500 4x4. about a month ago i went to start my truck and it took about 20 sec to start. So i figured it was the fuel filter changed it and it started fine for about 2 days. I thought maybe the lifter pump was going bad so i changed that to a carter in line pump using a fitting on the back of the filter housing. The truck started fine for a day. I checked to see if the pump was pumping fuel by having some one crank the motor over while i looked in the filterhousing and its getting fuel. The only way i can get it started is by unscrewing the filterhousing cap and sloshing the fuel around until its foamy then it will start around the third try. When i shut it off it will restart about five times then i have to do this again. If i drive it it runs great idles good has power etc but wont start again unless i stir the fuel up. I have not notiiced any leeks in the fuel system. Any help would be great i dont want to have to borrow my budies ford!!!!!!
Old Aug 23, 2008 | 04:11 AM
dozer12216's Avatar
Check fuel pump pressure while running.
Old Aug 23, 2008 | 09:22 AM
dieselrob's Avatar
The source of your problem will be the injectors. Its an 03 thing. I went threw it last fall. Its a great time to get aftermarket ones if you dont have a warranty. The injectors leak off the pressure slightly and it make the lines get air in them and hard start happens.
Old Aug 24, 2008 | 09:33 PM
Thanks guys! I talked to a diesel mechanic and he said the same thing about the injectors but that i should check all the injector lines first. Il let ya know what the prob is after i put a new starter in it!!!!! Or if it ever gets fixed
Old Aug 29, 2008 | 05:00 PM
It was #5 injector that went bad
Old Aug 29, 2008 | 07:12 PM
J Lent's Avatar
My brother had the same thing happen, changed a injector, 2 more went bad within a week. He replaced them all with II 3 flows, problem solved for a couple months, now he has a appointment Tuesday, same issue.
Old Aug 31, 2008 | 11:03 PM
Thats not good!! Theres a guy that rebuilds them 2 hrs away from me for 175 bucks.im gona drop the injector off tuesday. I would replace them all but im short on cash. Well see what happens.
fourthandgoal
88
Dec 27, 2011 05:39 AM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
L. D. Bryant
Nov 17, 2002 12:18 PM
