02 6speed question
Old Feb 17, 2005 | 06:55 PM
Jaa's Avatar
Jaa
Smile 02 6speed question
I have a 2002 3500 (cab and chassis) 6 speed transmission. Lately its ben tricky to get into gear. But only while not moving. Shifts perfectly while under way or if I tap the throttle while sitting still. Is this common? Also, any one know what make of transmission this is. When I bought it, the brochuer said (available allison transmission) Thanks
Old Feb 17, 2005 | 07:19 PM
hotdram's Avatar
Your tranny is the NV5600. New Venture is the manufacturer. What you are describing about having to blip the throttle is common. Lots of folks run Redline gear oil (MTL) in it to help with smoother shifting and get rid of the notchy-ness.
~Rob
Old Feb 17, 2005 | 07:33 PM
Jaa's Avatar
Jaa
Thanks for the help hotdram.
Old Feb 17, 2005 | 07:49 PM
4x4dually's Avatar
Amen, Jaa. Mine too. I have 50,000 miles on her now and it is getting worse. I sold my '99 5 speed because the pilot bearing was going out and it wouldn't shift worth a toot. I'm glad this is common. It really bugs that crap out of me though. I hope this tranny is better than the one in my '99. Good thing is, this '02 H.O. will out pull my '99 any day.
Thanks for bringing this up! Maybe someday someone will make a tranny worth putting in a high torque truck that will last.
Old Feb 17, 2005 | 08:10 PM
hotdram's Avatar
Anytime Jaa. The most common complaint about the 6 speed is the notchiness which can cause missed shifts (especially going into 4th and 5th gear). Seems to happen to me when I least need it to happen (like merging on the highway). I also find myself having trouble getting into 1st or 2nd gear when stopped. I blip the throttle and feather the clutch a little and then it will slip in. I bought the Redline MTL gear oil the other day and got the 17mm hex head that you need to open up the fill port on the tranny but just haven't had time to change the oil yet. I am hoping it helps.
~Rob
doubledodge2003
Jul 18, 2006 09:48 AM
Dieselbuilder
26
Apr 26, 2003 06:27 AM
Jan 18, 2003 06:39 PM
state line
Dec 9, 2002 10:40 AM
alleyyooper
16
Nov 15, 2002 08:55 AM
