01 Tq Locking And Unlocking
Old Oct 26, 2007 | 06:18 PM
weldman05's Avatar
Hey guys on the way to work this mornin, my tranny started locking and unlocking the TQ. Remember this full BILLET ATS Tranny has only 6000K miles on it. I talked to a guy down at Scheid were the work was done and he said it could be a bad ground, whats you guys oppinion? It is very intermitten
Old Oct 26, 2007 | 07:30 PM
cejrunner's Avatar
Could very well be a ground. Check battery connections, if corroded that cold cause you some trouble (it did for me). Maybe someone will chime in and tell the locations of the grounds to check if the battery check doesnt fix your problem.
Old Oct 26, 2007 | 09:24 PM
J BODY's Avatar
Cheap and easy: clean batterys, cover the blk/tan wire that runs over the alt with foil tape, disassemble the two gray connectors near the right side (passenger side) and solder them together and shrink wrap them.
bcool
Jul 14, 2007 11:32 AM
dltriolo
28
Mar 12, 2007 06:45 AM
dozer
Oct 12, 2005 10:52 AM
whosyrdady
Sep 25, 2005 11:07 AM
