Sponsored by:
Sponsored by: CARiD
Why the 6.7
Old Jul 12, 2006 | 10:49 PM
Rammandan's Avatar
Why the 6.7
why is dodge going to a 6.7 litre engine in the new 07 cab and chassis trucks.what is the benefit.
Old Jul 12, 2006 | 10:51 PM
robert chilton's Avatar
meet the new emmissions levels. Our trucks will see them soon enough.
Old Jul 13, 2006 | 12:03 AM
Smkndzl's Avatar
And Cummins will no longer produce the 5.9 liter engine.
Old Jul 13, 2006 | 06:25 AM
jrs_dodge_diesel's Avatar
I highly doubt that. The 5.9L B series is one of Cummins most succesful engine lines ever, why get rid of a good thing?
Old Jul 13, 2006 | 06:36 AM
Duallydog's Avatar
Progress, probably.
Old Jul 13, 2006 | 06:48 AM
DieselDaze's Avatar
EPA requirments.
This has been the demise of many "good things".
Rich
Old Jul 13, 2006 | 06:53 AM
96_12V's Avatar
The same reason you no longer see Duetz Air-cooled diesels in this country: Emissions regulations. It's often easier to redesign instead of revising again. But with the pending '07 reg's, Nothing has been "easy."
Our view of Diesel trucks:
C.A.R.B. and EPA's view of diesel trucks (and engines):
Old Jul 13, 2006 | 07:46 AM
J&L's Avatar
J&L
the 5.9 was being used before Dodge started using it. It has many uses in consruction equipment/mining/marine/agriculture/generation/etc. Dodge may drop it in the Ram truck line but its a Cummins engine and has many other applications.
Old Jul 13, 2006 | 09:00 AM
Forrest Nearing's Avatar
Originally Posted by DieselDaze
EPA requirments.
Rich
they will continue to make them in marine and industrial versions for YEARS
Old Jul 14, 2006 | 12:03 AM
mr T's Avatar
believe it or not bigger displacement and more fuel are the two ways the companies are using to meet EPA standards...yep thats right u gotta burn more fuel to be "efficient"
Old Jul 14, 2006 | 12:19 AM
Begle1's Avatar
The 5.9 engine sees operation on seven continents and seven seas, there have been millions upon millions produced, and is arguably the most widely used engines of all time. Even if EPA regulations outlawed it, then Cummins would still produce it for the majority of their market not under EPA jurisdiction.
At least, that's what I'd figure.
Old Jul 14, 2006 | 10:56 AM
HOHN's Avatar
EPA doesn't care about efficiency-- they log emissions.
The Europeans value efficiency over emissions (correctly, imo), and that's why they have so many diesels. I'm not aware of any huge smog problems in Europe that are worse than the US, even with our "cleaner" cars
The 5.9 will die in those applications subject to emissions, which is an ever-dwindling category. First emissions only applied to cars, then to "light trucks" (under 8800# GVWR, i think). Now the apply even to semis, mining truck, power plants, and gas trimmers. Anything with an ICE has a good chance of being regulated.
The 6.7 is the future because of "power density" and NOx. You can make all the power you'll ever want with the 5.9 for sure-- but you can't do that AND pass emissions-- the NOx levels will be too high every time. So you have to increase displacement to decrease power density (or HP/cubic inch) which will lower NOx emissions so you can pass.
The ironic thing in all this is that HIGH power density is a hallmark of efficiency. It's MUCH more efficient to max out a small engine than to have a larger one loafing along.
So, in an effort to save us-- the great unwashed masses-- from ourselves, our trusty US GUVMINT is forcing less efficiency upon us.
Given the price of oil, I think this is a mistake.
jh
Old Jul 14, 2006 | 11:54 AM
jh
not for a government with a lot of ties and interest to and in the oil industry!
Old Jul 14, 2006 | 03:01 PM
Duallydog's Avatar
Supposedly this larger engine is more fuel effecint than the 5.9. I'll believe it when I see posts to the effect of "OMG this thing got over 20mpg on the way home from the dealer".
Old Jul 14, 2006 | 04:03 PM
Keep it away from politics, guys.
