Sponsored by:
Sponsored by: CARiD
Where to buy Portable Diesel Generator?
Old Jan 15, 2007 | 09:41 PM
LethalInjection's Avatar
Where can I buy a portable diesel generator? Any where in Michigan?
Old Jan 15, 2007 | 11:39 PM
ridepayson's Avatar
Go to an r.v. dealership and buy a kipor diesel -- they are very quiet and extremley fuel effecient. reasonably priced too.
Old Jan 16, 2007 | 03:52 AM
Jim Lane's Avatar
For what purpose and how many Kilowatts are you talking about?
Standby, RV?
Onan Quiet Diesels are nice.
http://www.onan.com/onan/;jsessionid...questid=162316
Old Jan 16, 2007 | 07:14 AM
mainly looking for a emergency generator to keep things going when power goes out so anywhere up to 10k
Old Jan 16, 2007 | 07:16 AM
Standby, RV?
Is the onan a diesel? I only see where it says gasoline. Would be nice to have something made by cummins
Old Jan 16, 2007 | 07:43 AM
MedicShawn's Avatar
You could also look at www.Northerntool.com
Old Jan 16, 2007 | 10:53 AM
SoTexRattler's Avatar
Heh Heh, LethalInjection, take a look at who owns ONAN lock,stock and barrel...
Are you looking for something with "wheels and handles" type of portability something like this?http://cgi.ebay.com/7500W-Electric-S...QQcmdZViewItem
or something a little heavier that can be "dragged or lifted into position" portable?(like this)http://cgi.ebay.com/Northern-Lights-...QQcmdZViewItem
I had always thought that if I ever lived up where ice storms were a way of life, I'd get something like the following. This is a Kubota powered Onan marine genset w/o radiator. I've always thought this would be ideal for plumbing into a home's hot water heating system.
http://cgi.ebay.com/ebaymotors/ONAN-...72655861QQrdZ1
I'm rather partial to the little Kubota engines as they are pretty bulletproof and ULTRA-reliable. They have a very wide distributorship for parts and svc.
I have a 6Kw kubota powered genset/light tower with a 30+ gal internal tank. On one tankful It'll run for 60+ hrs at rated load.
1800rpm = last forever
K.
Old Jan 16, 2007 | 12:11 PM
mule3010's Avatar
What STrattler said. Also you can buy some real inexpensive Chinese portable diesel gensets. I have one (6500w) I paid less than $800.00 new for. It only has a couple hundred hrs. on it but so far so good.
Joe
Old Jan 16, 2007 | 12:35 PM
John Faughn's Avatar
I got some of the chinese [ junk ] would not do again , unless it was an emergency and I could not aford at the time , witch is why I bought the last one .
Every time I used it something went wrong or broke , I like to shut off petcocks when I shut down , this one broke off 3 times , threads are different than any replacments avalable , no screen in the petcock tank end , so the fuel leaked out when I drove with it in the be of the truck on an on an on an on it went .
The next time I will get a Miller welder genset , [ comes in diesel { for twice the price }] now besides power it can work also , 2 cylinder , it will put out 10k while welding .
Old Jan 16, 2007 | 12:52 PM
mule3010's Avatar
Ya, I've heard those Chinese genset horror stories. I guess I'm just lucky. Besides it's one of 4 so if it takes a dump it's not the problem it could be otherwise.
Joe
Old Jan 16, 2007 | 01:13 PM
Originally Posted by John Faughn
...The next time I will get a Miller welder genset , [ comes in diesel { for twice the price }] now besides power it can work also , 2 cylinder , it will put out 10k while welding .
I don't weld but if I did, that is definitely what I would have.
(unbelievably )Our plant recently wound up with 3 of those little Miller diesel welders in addition to the bigger stuff.. VERY NICE UNITS! They have tiny wheels, but are not roadworthy. Only for dragging around the plant very slowly.
The Miller's we've got have small Kubota's in them, and they run @3600RPM.
A nice feature is to be able to get 120/240vac 10kw 60hz power, and when unloaded the engine will throttle back to idle, just like when welding(quiet too!).
K.
Old Jan 16, 2007 | 01:31 PM
Jim Lane's Avatar
Here they are.
Jim
Diesel,
http://www.onan.com/onan/rvgenerator...torDisplay.jsp
http://www.onan.com/onan/mobilegener...torDisplay.jsp
Propane,
http://www.onan.com/onan/homestandby...eratorHome.jsp
Old Jan 16, 2007 | 01:45 PM
hubmonkey's Avatar
Check Mayberrys online. They have by far the best prices I have seenon quite generators. You have to call them to get pricing.
Hub
Old Jan 16, 2007 | 03:08 PM
spitfire9137's Avatar
You said you wanted something with a cummins in it, here you go.
Old Jan 16, 2007 | 09:43 PM
BC847's Avatar
1st Generation Admin
Arrow
If you've got a Diesel tractor in the shed you might consider one of these ~
