Sponsored by:
Sponsored by: CARiD
Where to buy Portable Diesel Generator?
Old Jan 16, 2007 | 09:50 PM
spitfire9137's Avatar
Originally Posted by BC847
If you've got a Diesel tractor in the shed you might consider one of these ~
They are nice, but I don't like the idea of having only one tractor and commiting it to the generator head, never know when you will need it at the same time.
Old Jan 16, 2007 | 10:53 PM
MTGunNut's Avatar
Originally Posted by SoTexRattler
Heh Heh, LethalInjection, take a look at who owns ONAN lock,stock and barrel...
Are you looking for something with "wheels and handles" type of portability something like this?http://cgi.ebay.com/7500W-Electric-S...QQcmdZViewItem
or something a little heavier that can be "dragged or lifted into position" portable?(like this)http://cgi.ebay.com/Northern-Lights-...QQcmdZViewItem
I had always thought that if I ever lived up where ice storms were a way of life, I'd get something like the following. This is a Kubota powered Onan marine genset w/o radiator. I've always thought this would be ideal for plumbing into a home's hot water heating system.
http://cgi.ebay.com/ebaymotors/ONAN-...72655861QQrdZ1
I'm rather partial to the little Kubota engines as they are pretty bulletproof and ULTRA-reliable. They have a very wide distributorship for parts and svc.
I have a 6Kw kubota powered genset/light tower with a 30+ gal internal tank. On one tankful It'll run for 60+ hrs at rated load.
1800rpm = last forever
K.
cummins, right?
Old Jan 17, 2007 | 12:24 PM
SoTexRattler's Avatar
Originally Posted by MTGunNut
cummins, right?
Bingo!
K.
Old Jan 17, 2007 | 12:33 PM
And,... THey are rather pricey too!
But, I like the idea of something that can sit in the shed for yrs on end without it's fuel or battery going to pot. My co-worker has 2 or 3 diesel tractors that he works, and lives in an area prone for blackouts. I told him about the PTO gens and he said, "Yeah, I looked into them once but they wanted WAY too much for one". He said for the price of one, he could buy a used genset... He's still looking for a used PTO gen...
The one I saw also had a really nice looking 3pt hitch base that carried the PTO gen. It looked REALLY easy to hitch up the PTO gen and then drive the tractor w/gen to the house and hook up the power. That makes it easy to drive the tractor to the fuel stg tank and fill up and then return.
K.
Old Jan 17, 2007 | 02:16 PM
Northern tool has a 27.5kw pto gen head for $2150. Then they have a little trailer to put it on for $570. Plus the shipping for both.
I scored a nice little deal on a Lister Petter 15kw genset for $500.
Old Jan 17, 2007 | 04:48 PM
BC847's Avatar
1st Generation Admin
Arrow
And,... They are rather pricey too!
And there's good reason.
Those Junk gen-sets and those designed like them typically are of the 2 pole design. As such they must run a approx 3600rpm. The same usually use plastic housing ends supporting cheap bearings. They just don't last in my opinion.
The more expensive type are of a design that uses 4 poles. With that they run at 1800rpm and incorporate much stouter cast iron housing ends, better cut gear drives etc.
Also be aware, the cheaper units don't have much of a surge capacity. This becomes VERY important when one has to start a larger load such as a heat pump compressor. As an example: a given motor may only require 5 amps to run, but requires up to FIVE times that (25amps) to start. (That pictured above sports a 25kw continuous capacity and a 50kw surge capacity).
Spitfire brings up a good point. Let it be known that as is standard Murphy's Law; When one purchases a standby gen-set, the electric power will not fail for the next five years (NOT ONCE!!) It'll hurt your feelings to invest thousands of dollars only to see it be a wasp nest shelter.
Old Jan 17, 2007 | 07:02 PM
jkitterman's Avatar
Home Depot lists at least one online.
Old Jan 17, 2007 | 10:36 PM
DaveB.inVa's Avatar
Nothing wrong with a two pole unit if it is built right, so don't completely rule out a two pole generator just because its two pole.
Old Jan 17, 2007 | 11:18 PM
PaulDaisy's Avatar
I looked into a gen, and decided although I like diesels, not enough to justify paying 2x as much for an intermittent use engine. A gasser will be Ok for me, If I had a workplace to run off of it, it would make sense and pay off in longevity and fuel savings. But for once-in-a-while blackouts, a gasser will do. So I went with a Champion, which are sold at Cabelas for $300. I am not going to run my heat pump off of it (in the summer, I can survive the heat for a while, as long as the fridge runs). In the winter, the 4 kW will run the furnace, which is a safety issue. This is how I judged my needs and the savings will let me buy more things for the truck
-P
Old Jan 18, 2007 | 11:19 AM
xmr's Avatar
xmr
I bought a 6000 Watt gasonline generator and converted it to run on Natural gas, propane or gasoline. That way I don't hae to have a lot of fuel sitting around, just in case I need it.
jj3500
Jan 28, 2015 09:59 AM
djcheez
Aug 30, 2005 02:46 AM
May 25, 2003 04:51 AM
Homestead
Apr 24, 2003 11:27 PM
Bobp
Mar 14, 2003 05:52 AM
