Sponsored by:
Sponsored by: CARiD
Water/Meth Injection??
Old May 30, 2006 | 12:14 PM
JimmieD's Avatar
What's the real deal on water/meth injection? Interested in hearing from users if it really works, is worth the kit price, and who has the best kits. Also thinking there may be a fairly simple homebrew method of building my own kit if the system actually works.
Never seen actual dyno printouts to prove some of the claims on the net, so any light you can shed on that is appreciated. Is it a good upgrade? Thanks!
JimmieD
Old May 30, 2006 | 12:58 PM
JD Dearden's Avatar
Yes it does work, however this is mostly effective for the lower egt levels, you can count on about 200 degress less when driving or towing up hills. And somewhere around 50 horsepower. I only did it for towing up steep hills. Snow performance makes a good kit, but the biggest and baddest kit is made by hypermax it was produced for the ford but I think you can run it on the cummins.
Old May 30, 2006 | 01:35 PM
JimmieD's Avatar
Thanks JD! Just what I wanted to hear as I'm thinking about it for a Cummins 4BT conversion truck used for full time RV towing. A few more ponies hitched up would be real nice, and only need it occasionally on those steep hills and long grades.
JimmieD
Old May 30, 2006 | 02:10 PM
dodgezilla04's Avatar
hey JD, how long does say a gallon of mix last when towing? Meaning, will a gallon last for a fuel tank full, or do I have to pull over more often? I need something to keep the egts down, before I break the bank and upgrade to twins.
Old May 30, 2006 | 02:48 PM
JD Dearden's Avatar
Well it depends, on mine with the jets that I am running I can go around 15 miles will under constant boost but I am tapped into my stock fluid box(washer fluid) which is bigger than the one the kit provides. You can run smaller jets too if you want to reduce the flow.
Old May 30, 2006 | 04:09 PM
It works well for me. See my sig for dyno results. EGT drops 200 degrees. I feel the Snow Stage 2 kit is worth it if smooth response is important to you. If a nitrous-style kick in the pants is what you want, get a kit with a switch or build your own.
Old May 30, 2006 | 10:59 PM
thanks, smoke perf has an option for a bigger tank, it would be nice to go between fill ups. there are a lot of mountains here in western washington.
jdpiii
Jun 19, 2008 07:34 AM
trik396
Competition / Pulls / OffRoad
13
Jun 29, 2005 02:16 PM
mcevins
May 13, 2004 05:36 PM
