Sponsored by:
Sponsored by: CARiD
View Poll Results: How long do let your truck warm up?
Barely
36.84%
Less than 5 minutes.
42.11%
5-10 minutes.
17.29%
15 minutes or more.
3.76%
Voters: 266. You may not vote on this poll
Warming up
Old Feb 27, 2008 | 07:11 AM
salesrep's Avatar
Warming up
Old Feb 27, 2008 | 07:31 AM
JD730's Avatar
It depends, if the high idle will come on I'll let it run 5 to 10 minutes otherwise 30 seconds and I'm on the way. I don't hammer it, but I drive it gently till the temp gauge comes off the lower peg.
Old Feb 27, 2008 | 08:45 AM
haloman's Avatar
X2............
Old Feb 27, 2008 | 08:52 AM
dieselfuelonly's Avatar
DTR question asker
I let the oil pressure come up and idle for maybe a minute... then put it in drive and go, but take it easy until it warms up.
Old Feb 27, 2008 | 08:53 AM
GIT-R-DONE's Avatar
In the summer time, a few minutes and I am off.
Winter time = 5-10 minutes.
Guess it depends on what part of the country your in, JMO
Old Feb 27, 2008 | 09:01 AM
rustyshakelford's Avatar
depends how much time i have...anywhere from 5-45 mins or other times, i just jump in it and go
brett
Old Feb 27, 2008 | 09:20 AM
CD in NM's Avatar
I selected the less than 5 minutes, but time to clarify that selection.
I flip on my PacBrake, when the engine temp reaches somewhere around 170*s the brake kicks off, that's when I take off. I still take it easy until the engine reaches full operating temperatures, but the brake kicking off is my starting point. I see that as a nice constant measuring stick to always doing the same startup/warmup, takes out the guesswork of when to go down the road.
CD
Old Feb 27, 2008 | 09:50 AM
mj007's Avatar
Originally Posted by haloman
X2............
X3 ....
dssimecek's Avatar
Short sleeve shirt weather temps, about a minute.
Cold but not cold enuff to plug in, 3 to 4 minutes
Plug in temps 3-4 minutes.
Houston don't get real cold.
Old Feb 27, 2008 | 10:02 AM
cincydiesel's Avatar
In the Winter I go out start the truck set the high idele to 1100 rpm. Go back inside for a
Old Feb 27, 2008 | 10:08 AM
donnee's Avatar
I do the same as the above poster.
So Cal dont get that cold but the high idle is nice when it is cool out.
Old Feb 27, 2008 | 10:09 AM
ofcmarc's Avatar
Summer I wait for oil pressure and go.
Winter I let it run on with the hand throttle set for 15+ min when in the - temps and then go. It won't get warm until I drive for a bit anyway.
Old Feb 27, 2008 | 10:23 AM
Diesel Demon's Avatar
In the winter I let it warm up 15 min or more. summer about 5 min
Old Feb 27, 2008 | 11:35 AM
DBLR's Avatar
Even at -24 below zero I never let it run for more then 5 minutes as its a waste of fuel and it will not warm even with it running at 11-1200 RPM's. I also keep the engine speed under 1800 RPM's until the temp gauge goes above 150 degrees.
Old Feb 27, 2008 | 12:02 PM
ofcmarc's Avatar
Running an engine warms more than the engine. It helps warm the trans/ t-case as well. 5 min is not enough for that reason IMHO.
