Sponsored by:
Sponsored by: CARiD
Turn up fuel CAT 3306
Old Sep 23, 2006 | 02:12 PM
12valve's Avatar
How do you turn up the fuel on CAT 3306?
Its in a 1994 D350D articulated dump truck
is there anything else i can do to add some more power?
Can theyr timing be advanced? would it help? we are at 5000 feet elevation.
The ones in the middle (84) smoke a whole lot more, and have more power, then the
one on the left (94)
thanks!
Old Sep 23, 2006 | 02:54 PM
Kman9090's Avatar
I dont know how to do it but i know it can be done, i watched a mechanic turn up a 3406 on a cat 627 front motor and the rear engine is a 3306 and the mechanic said he could also turn that motor up to if I didnt like the performance from the front motor
Old Sep 23, 2006 | 09:15 PM
nickleinonen's Avatar
when i was in diesel school, the one teach there did lots of work on cat engines with the inline pumps... when they got worn out, the pumps would actually put out more fuel under load than a fresh pump would.. there was always complaints about low power when they installed rebuilt pumps..
Old Sep 24, 2006 | 06:56 PM
dodgeguy71's Avatar
I built a couple of them pumps while at CAT, but am by NO MEANS an expert. I am thinking that maybe you have to do something to the governor or rack adjustment? Like I said, not really to sure but those things ring to mind and not something I would suggest doing by yourself. May end up with a boat anchor instead of an articulating truck. Our fuel pump guy was a wizz at it and could work magic with a fuel system, but he had been doing it for like 15-20 years. I'd find a mechanic who is looking for a little side money and REALLY knows what he is doing.
Old Sep 30, 2006 | 01:25 PM
12valve's Avatar
How about advancing the timing??
IS it possible?
The truck seems to be verey slow, even to rev up, in neutral!
Kinda like my Dodge did, before i advacned timing
Old Sep 30, 2006 | 10:23 PM
dodgeguy71's Avatar
As far as I remember the gear train on the front has letters or these < and that is how you set the gears up. Pin the flywheel and pin the pump to get it timed right for #1 cylinder. I don't think you could actually go in and offset the teeth and if you did you would have to know for sure how many teeth you have offset it. I can't remember exactly, but it was a couple degrees per tooth. You'd be better off letting someone mess with the rack adjustment, maybe can get it to open the plungers up sooner? I also thought there was an air/fuel ratio, or something like that.
I'll have to see if I can find my 3306 book in the shop. It has stuff in there about the pump, adjustments and maybe I can be a bit more clear.
Old Oct 1, 2006 | 06:29 PM
12valve's Avatar
thanks would be appreciated!!!
Old Oct 2, 2006 | 12:18 AM
XLR8R's Avatar
I thought it was bad to advance the timing on the big diesels...
Old Oct 3, 2006 | 07:14 PM
just as bad as advancing the timing on a smaller diesel too... 'cept larger diesels cost much more and spend much more time making its rated HP, so failures cost more and can happen more often when engine is uprated..
Old Apr 28, 2012 | 04:09 PM
ISBpower's Avatar
advancing the timing is easy i did it on our steiger tractor that has a 3306 just pin your pump make sure the gear is loose on the pump shaft and then check your pin holes in the flywheel and rather than lining them up just turn the engine forward so the flywheel hole goes over top the bellhousing hole just about half a hole to be safe then just torque down the gear to the pump shaft and the fueling on ours was done by turning the 2 alen head screws out 1/4 of a turn each but i forget which cover has to come off
Old Apr 28, 2012 | 05:32 PM
TheMrAMack's Avatar
http://www.freewebs.com/nevrenufhp/
Here's a good website that tells you how to turn the fuel up on just about any diesel. Not many pics tho.
Im assuming your 3306 is a newer model and not a late model. Im familiar with the 3406 B and C models, but not a 3306. Good luck!
NE frmhnd
Big Rigs
Nov 27, 2011 11:47 PM
jzangger
Big Rigs
Jan 20, 2011 09:34 PM
dzl_damon
Big Rigs
May 19, 2010 09:55 PM
BlueDually
Nov 18, 2007 08:38 PM
Rare1
Jul 17, 2004 08:48 AM
