Turbo guys please help...........
Can anyone tell me about this turbo. Id like to use it in a twins setup, or as an upgrade from the factory turbo . I dont know anything about it other that it is an AiResearch M24 and it flippin huge! What do yall think?
I don't know how it would work on your truck. I do know that it was designed to work in tandem with the blower on the 8V92. In my opinion I don't think our ISB will drive it, those 8V92 move a LOT more air than our little 5.9's do.
Tim
Tim
Yeah, the displacement of the 8V92 is 736 cubic inches, our 5.9 Cummins is 360 cubic inches. That is just over twice the size of our engines. You would need a lot of fuel to get that turbo moving.
Hell just get the blower off it and use that too
Id like to use it for twins, I dont know how it would work with the factory HX35 spooling it up.............
Any ideas from you twin turbo guys?????
Keep in mind that a blower builds no boost on a Detroit. It is only there to move air as the cylinder has to be filled and exausted on every stroke. The only boost comes from the turbo. The engine also moves that 736 cubic inches of air on every revolution.
It is hard to tell from the pics without some measurements, but I can tell you for sure it will not work as a single on anything other than a monster race or pulling engine. Even at that you would need a smaller turbine housing. I run a TV71 Garrett(Airresearch) with a .70 A/R turbine(that one has a 1.05) on one of my turbo gassers that is very similiar to the turbo pictured. It is a 410cid engine and starts making boost around 3800RPM. I suspect it would take that or more to start making boost with a 5.9. I dont know if you would ever get it up to full boost before you ran out of RPM unless you are turning 5K and fueling the **** out of it.
Now, in a compound setup it could most likely be made to work but you would need to do some homework to figure out what turbine housing and what will work as a complimentary turbo with it.
In used condition they are not worth a whole lot unless someone just needs it for a project. I paid $175 for mine on fleabay. If you want to unload it, I might be interested for a future pulling project. PM me.
Jordan5687
35
Oct 2, 2007 06:12 PM
srtdiesel
Apr 30, 2007 06:51 PM
