Sponsored by:
Sponsored by: CARiD
TQ wrench
Old Feb 24, 2003 | 10:53 PM
dodgeman01's Avatar
TQ wrench
I was wandering if you could use a inch pound wrench to do the vlaves on a CTD. 6x12=72inch pounds right. I can't seem to find a 6lp tq wrench.<br>DM01
Old Feb 25, 2003 | 06:50 AM
Rammin On's Avatar
Re:TQ wrench
What do you need a 6 lb torgue wrench for? If you are using this for the preload on the feeler guage .... it's 6 inch lbs.<br><br>
Old Feb 25, 2003 | 09:42 AM
Commatoze's Avatar
Re:TQ wrench
According to this place, that is correct.<br><br>
Old Feb 25, 2003 | 09:45 AM
Rammin On's Avatar
Re:TQ wrench
01<br><br>Your conversion is correct .. but don't use 72 inlbs to adjust your valves ...<br><br>
Old Feb 25, 2003 | 09:55 AM
dodgeman01's Avatar
Re:TQ wrench
Then how many do I use to adjust the valves??<br>Dm01
Old Feb 25, 2003 | 10:44 AM
Rammin On's Avatar
Re:TQ wrench
6 inch pounds .....
Old Feb 25, 2003 | 01:33 PM
dodgeman01's Avatar
Re:TQ wrench
thanks. I was told 6 FTlbs. not INpounds. oops.<br>dm01
Old Feb 25, 2003 | 08:57 PM
Monty's Avatar
Re:TQ wrench
Be careful when using the 6in lb wrench on the 12v engines. I had posted awhile back that you could use this tool and shave quite a bit of time off. (Very important if you are a service tech). But, I had only used this tool on the 24v and the 3126 CAT. Little did I know that the valve springs where heavier, stiffer, in the ISB. I tried the wrench on my own truck. 6 in lbs is way too much, the valve spring compressed a good 1/4&quot;.
Old Feb 26, 2003 | 08:50 AM
Rammin On's Avatar
Re:TQ wrench
Okie brings up a good point .... I don't use the inch pound method ... watch the spring compression when you do ... feel by hand is much better.
bobva
Nov 26, 2006 11:16 AM
blue eye bandit
Nov 12, 2002 07:25 PM
ToolManTimTaylor
25
Nov 8, 2002 07:51 PM
rweis
Oct 21, 2002 10:30 PM
