Sponsored by:
Sponsored by: CARiD
Things I have had to replace on my Cummins
Old Nov 25, 2003 | 03:56 PM
Palmetto_kid's Avatar
1997 2500 2wd 5sp. im betting allot of us will have had the same problems.
1. Lift Pump
2. headlight switch
3. vacuum actuator for a/c control
4. lower ball joints
5. 5th gear
6. nv4500 tailshaft seal
7. mod. a/c drain to keep cab dry
8. starter contacts
all that outa 125k miles. not as bad as some.
Old Nov 25, 2003 | 04:00 PM
Hoss's Avatar
Thats MR Hoss to you buddy!
Re:Things I have had to replace on my Cummins
Someone stole my silencer ring, but I'm not going to replace it. ;D
Old Nov 25, 2003 | 07:18 PM
RamThatStroker's Avatar
1995 2500 4x4 5-sp with 200,000+ miles,
1. T-Case (my fault)
2. Steering Box (my fault)
3. Track bar
4. 2 steering stablizers
5. Front and Rear axle seals
6. 5-th gear nut
7. Return Fuel hoses
8. Throttle cable assembly
9. Two sets of brakes
10. One clutch (Putting SBC in this weekend)
11. Two slave cylinders
12. one clockspring
I don't think its that bad for the number of miles on it don't you. ;D.
Bombing addons:
1. ATS Manifold
2. 4" Straight piped exhaust
3. Banks fuel plate
4. 3K GSK
5. Isspro EV Gauges
I'm not stopping till I break 400 hp so more to come!!
Old Nov 25, 2003 | 07:37 PM
Shovelhead's Avatar
Administrator / Scooter Bum
My '99 in 55,000 miles
1 lift pump @ 32,000.
2 rear turn signal bulbs.
Ramflasher's Avatar
1. Oil Pressure sending unit
2. shocks
I have a bit over 75,000 miles on my '99.
Old Nov 25, 2003 | 09:19 PM
TomW's Avatar
156,000 on mine. Only thing I've had to replace is the occassional headlamp bulb, one tail light bulb and a high pressure fuel line.
Old Nov 25, 2003 | 11:48 PM
dodgeman01's Avatar
on my 93 with 180k I replaced a tail light bulb last year and one batterie and two sets of brakes ;D I love this truck
DM01
Oops forgot about a new pump. My fault :-[
DM01
Old Nov 26, 2003 | 12:49 AM
DODGE4X4's Avatar
2001, 2500 4x4 auto
1. Lift Pump @ 30k
2. 1 Boot @ 60K
3. Turbo @ 63K :'(
4. Shift Sensors in Tranny @ 77K
Old Nov 26, 2003 | 04:24 AM
pappyman's Avatar
1995 3500 2wd
Battery's 2 ea
Headlite 3 ea
Tranny 1 ea
Brakes front 2 ea
Brakes rear 1 ea
Tires 3 complete sets
Windshield 1 ea
Injectors 6 ea
Tranny temp sensor 1 ea
Except for the tranny everything replaced can be considered normal wear and tear
Old Nov 26, 2003 | 10:27 AM
thumper 549's Avatar
replaced the high quality plastic piston oil jets (piston coolers) with low quality steel ones
Old Nov 26, 2003 | 11:02 AM
Cowhand's Avatar
Hmmm.....
1996 4X4 with 178K,
3 track bars
1 oil pressure sender
Return lines
a perfectly good head gasket
1 serp belt
1 rotor
1 pair of batteries
Not to mention normal wear stuff like tires, windshield wiper blades, bulbs and misc. things that cost less that $10.
Stock tranny has lasted 178K with 37" tires and motor mods listed in my sig. It's finally on life support, I'm just hoping it holds together until I can fund the new trans.
Old Nov 26, 2003 | 11:14 AM
dsldan's Avatar
1999 121000miles
1 set of tires 72000miles
4 shocks 90000
1 fan belt 90000
2 sets front brake pads
1 ckp 97000
1 thermostat 118000
1 lift pump 120500
1 injector pump 120500
6 rv injectors
1 e/z
Old Nov 26, 2003 | 11:35 AM
dodgeman01's Avatar
I know we have done a few of these in that last few years so I will try to keep this one short lol and these are only the things that broke/wore out on the truck. I wrecked in and need a few front parts but thats not the trucks fault
94 Dodge
5 sets of tires
2 track bars
1 top right ball joint
1 set of tie rods
3 sets of breaks front 1 back
One ignition Wire
starter contacts
c-clip in the transfercase. 30min fix 4 dollars
two front u-joints
One clutch ;D
4 shocks
one tail light bulb
front light bulb
radio and speakers
Thats it
140k and tows /hauls /drives somewhere every day
DM01
Old Nov 26, 2003 | 11:42 AM
JyRO's Avatar
This is the complete list of things I HAVE HAD TO replace on mine:
1 lift pump @ 45,000 miles (under warranty).
That's it! 56,000+ miles on it now.
Original tires, brakes, bulbs, clutch, tranny, everything. Tires are lookin' good. Change oil, oil filter, fuel filter every 5k / 15k miles.
Optional replacements - Removed silencer ring, added EZ & boost elbow, RV275's, removed muffler. ~$660 total. Paid off truck April 5th, 2003. 13+ G's in the bank now, baby!
- JyRO
Old Nov 26, 2003 | 11:43 AM
BIG&BAD's Avatar
oh god i really dont want to fill this one out :'(
but here we go
my baby a 95 cummins 250 auto miles 204,000
1 tranny at 190,000
1 rear axel (from a 70 to an 80) 195,000
all the brakes at 195,000 front had stock rotors on it still never even turned
1 starter at 191,000
1 factory alarm at 192,000 couldnt start the truck anymore a will know car stereo shop couldnt fix it but i did
1 water pump at 203,000
1 set of tires at 193,000 needing new ones already
thats it.. not too bad but pricey
and all the normal stuff for a cummins (trackbar,shocks,etc,etc)
the truck got it first bomb at 196,000 miles
i got my baby at 170,000 miles from my dad
and still out pulls new Dmaxs and Psd's every time ;D
and loves to eat rice ;D
