Sponsored by:
Sponsored by: CARiD
Sterling axles
Old Mar 9, 2006 | 07:20 PM
lovemysan's Avatar
Sterling axles
I been considering my open axle situation and viewing how to best remedy it. I was over at the www.thedieselstop.com and noticed theres quite a few 10.25" sterling axles in the classifieds for $500 or less. I have one under my F250, its a full floater with limited slip. The LSD is nice and works good even with a 175k and it fully locks up on asphalt.
How do these axles compare to the d70? I don't think it would be worth the effort to swap over but I may measure just for fun.
Old Mar 10, 2006 | 06:08 AM
JD730's Avatar
I'm familar with the sterling having had a ford or two at one time and rebuilding one completely with a friend of mine once. Just make sure its a 97 or earlier axle, when they went to the new body in 99 they changed to the metric 8 lug bolt pattern. And they have 9/16" studs where we have 1/2" studs.
Old Mar 10, 2006 | 08:25 AM
big jimmy's Avatar
At least the ones under the Fords are narrow- thats why some guys shuck out 600 dollars for bolt on hub extenders.
I did not like mine on my PSD, compared to the Dana under my CTD.
Otherwise it gave me no trouble and when I changed lube for the first time @ 100,000 miles it looked pretty good in there.
Old Mar 10, 2006 | 08:55 AM
jkitterman's Avatar
The bolt pattern will be different. Ford is using a hub centric wheel. I don't know if you would be able to change out the axle shafts to match the dodge pattern.
Sep 22, 2019 07:27 PM
95black2615
Dec 22, 2007 10:54 PM
bigbrowndog
Sep 2, 2007 08:16 PM
SkyHarborCowboy
15
Sep 9, 2005 11:50 PM
