Sponsored by:
Sponsored by: CARiD
Sandwich oil adapter
Old Mar 27, 2007 | 12:16 PM
Clayten's Avatar
DTR's Toad Wrangler
Does any one know where I can get a sandwich adapter for my 94 12 valve. It seems you can get one for everything except a 5.9 Cummins.
Old Mar 27, 2007 | 01:31 PM
BigBlue's Avatar
Does this adapter allow you to toast sandwiches on your exhaust manifold?
Old Mar 27, 2007 | 02:52 PM
Clayten's Avatar
DTR's Toad Wrangler
How did I know that was going to come up? I want to do some plumbing and I need an adapter between the block and the oil filter. Ok I will show what I need.But I need one that will fit on a 6bt. 1" - 16 threads
http://perma-cool.com/Catalog/Cat_page28.html
Old Mar 27, 2007 | 04:42 PM
Lil Dog's Avatar
What are you up to? I think if you talk to Amsoil, they have that type of adapter for the bypass oil systems. Not sure...
Old Mar 27, 2007 | 04:53 PM
woodrat's Avatar
What are you wanting to add? There is already an oil cooler in the block, and if you are adding bypass filtration, you can do that right out of the top of the filter bracket.
Old Mar 27, 2007 | 05:24 PM
Clayten's Avatar
DTR's Toad Wrangler
Ya I want to add a by pass filter. I don't want to make a hole in the pan or the valve covers for return, and I was trying to not return it back through the oil fill cap.
Old Mar 27, 2007 | 05:30 PM
Ace's Avatar
Ace
Woodrat's right, I don't know of anyone that makes a sandwich adapter for the 5.9, and I wouldn't recommend it, if they did. here's how I did mine, not too hard if you can fabricate brackets and drill holes 'n stuff:
https://www.dieseltruckresource.com/...ght=gulf+coast
Old Mar 27, 2007 | 05:33 PM
woodrat's Avatar
Oh yeah, the return hole. my truck had the bypass stuff already installed when I bought it, so i didn't have to be the one to drop the oil pan..
wonder if you could put the oil return in the side of the timing cover somehow, although a valve cover would be easier.
Old Mar 27, 2007 | 05:38 PM
woodrat's Avatar
dang Ace, that thing is a monster!
my truck also has a bypass coolant filter set up too, with a spin on filter that I can get at napa.
Old Mar 27, 2007 | 05:42 PM
Clayten's Avatar
DTR's Toad Wrangler
Ya I like that. That is a nice clean way to return the oil, and the cap is not butchered. Sooo, how was the fitting in the oil fill tube made? Ya I just went back and looked at that again, that is real nice. I could feel comfortable with that one.
Old Mar 27, 2007 | 06:03 PM
Ace's Avatar
Ace
Just drilled a hole, threaded in a 90deg. barb with loctite, scuffed it up with sandpaper around the outside and smeared JB weld all over it. That tube is just plastic, so no biggie at all. I'm gonna shoot some flat black paint on there so it looks a little cleaner one of these days...
Old Mar 27, 2007 | 06:09 PM
Homestead's Avatar
Here is another simple way of doing it. It's the route I am going to take, just need the time to gather the pieces.
http://www.nwbombers.com/forum/index...howtopic=19867
Jeff
Old Mar 27, 2007 | 07:53 PM
Ace's Avatar
Ace
10um nominal? That's not a bypass filter. One nice advantage of returning the oil like I did is you can visually monitor the flow rate. This is helpful in fine tuning and determining when it is time to change the element.
Old Mar 27, 2007 | 10:22 PM
nickleinonen's Avatar
i someday plan on adding a bypass filter setup, and i think i will make up my own kit & maybe run a fleetguard lf777... 5µ is pretty fine enough for me.. but that puppy is big... almost 5"x10" spinon
Douglas2
Jun 13, 2010 04:57 PM
efbeason
Aug 31, 2007 04:28 PM
efbeason
Aug 31, 2007 09:09 AM
Bobcat698
Jul 23, 2006 05:29 PM
