Sponsored by:
Sponsored by: CARiD
running lean?
Old Jul 8, 2003 | 04:38 PM
remote control's Avatar
running lean?
if we increase our exhaust system and intake size. and have a boost pressure of 35-40psi. with stock injectors, can the engine run lean?
Old Jul 8, 2003 | 04:55 PM
BigBlue's Avatar
Re:running lean?
The leaner the better in a diesel. So to speak. You can't really run to lean. The leaner you run, the more fuel you are burning. The more fuel you are burning, the more power you are getting. Besides, running 35-40psi on a stock motor with no box is pointless. You don't have any extra fuel to burn so you don't need the extra boost to burn it. The more fuel you add, the more boost you need.
Old Jul 8, 2003 | 05:09 PM
Re:running lean?
i guess my real concern is, wasn't real happy pulling my 30fter. last w/e. only had this 96 for 4 mounths now. and i thought it should of done better. Running about 60-65 mph. on a hilly road, it was running about 1150-1200*f around 20-24 boost. do thease numbers sound fair?
Old Jul 8, 2003 | 05:12 PM
BigBlue's Avatar
Re:running lean?
Sounds spot on<br>
Old Jul 8, 2003 | 05:20 PM
Re:running lean?
thanks BigBlue<br>with my injectors being of a unknown to me, i was worried about the aftermarket stuff already done when bought.<br>sounds good to you sounds good to me.. thanks.
Old Jul 8, 2003 | 05:26 PM
BigBlue's Avatar
Re:running lean?
Quick question. Is your EGT pre or post turbo? If those temps are pre turbo, your alright. If those are post turbo, then you are in serious trouble. I don't think Banks upgrades the injectors. I'm not sure though. Sounds to me like you might need a little more boost though. 20-24 seems kinda low. How much smoke are you producing? A light haze at WOT is good. If there's a lot of smoke at WOT, then you need more air.
Old Jul 8, 2003 | 05:36 PM
Re:running lean?
i am pre. turbo. yea i think they are stock injectors.
Re:running lean?
no smoke at all that i have seen?
Old Jul 9, 2003 | 05:18 PM
BigBlue's Avatar
Re:running lean?
Then your fine. As long as you don't go over 1350 for more than a split second or so (1350 for 30 secs. is the max) then you'll be fine. Have fun with the truck.
Old Jul 17, 2003 | 11:37 AM
JyRO's Avatar
Re:running lean?
<br><br>Big Blue - That all sounds OK to me, except the 1st sentence quoted. If you're running lean, doesn't lean mean less fuel and more air beyond the stoichemetric (sp?) level? In other words, more air?<br><br>You're first sentence is confusing me...lean means less fuel. Running a tad on the rich side would cause the haze out the exhaust ... right? And more than a tad on the rich side blows some good smoke ... right?<br><br>- JyRO
Old Jul 17, 2003 | 01:31 PM
JyRO's Avatar
Re:running lean?
Howdy Gary!
I don't think your reply answered my question. At least not the way I *intended it*. But I do now think I know what BB meant.
Let see if I understand BB correctly. Running lean you burn more fuel - Translated (for my understanding): I think he means that you're more efficiently burning the fuel that is available when you're not running rich. And I agree with that.
But does adding fuel beyond an ideal (most efficient) level cause you to burn *less* fuel? I don't know. What I do know is that some of the extra fuel will not burn efficiently ... thus smoke.
The thing that confuses me most about conversations regarding lean and rich burns, is that I think most people assume there are 2 conditions: 1. Rich, 2. Lean. And because they only consider these 2 conditions, they *say* that lean is better.
However, I *think* really there's (at least) 3 conditions. 1. Lean, 2. Ideal (stoichometric (sp?)), 3. Rich
Something like this: | &lt;------- lean ------------&gt;|&lt;-- ideal --&gt;|&lt;----------- rich -----------&gt;|
My assumption is max power is about here^ ^Haze ^---- Smoke ------^
But where you get max power is NOT the leanest ratio. To the extreme, the leanest ratio is all air and no fuel. And we all know it will not run that way, much less be powerful.
Burning only PART of the fuel produces smoke in varying degrees, and indicates a RICH mixture
that is NOT efficient, and is not producing the best power in relation to available fuel... This is
why merely providing more BOOST, above that needed to maximize burning of available fuel, is
pointless, doesn't do anything but increase cylinder pressure, since all the fuel has already been
burned - NOR is addition of more fuel - and more smoke - beneficial either, since without added
air to burn it, it simply blows out the exhaust and creates higher exhaust temperatures...
Not only do I agree with this, but I never disagreed either.
Gasser or not, the ideal fuel ratio condition is when the truck doesn't smoke, but a *drop* more fuel and you start getting the haze (yet, the haze level is very very close and is a good measurable (visible) gage for good power).
How many beans do I have in me? Am I completely full? I realize diesels and gassers are different, but logically I can't be too far off.
- JyRO
Old Jul 17, 2003 | 02:03 PM
JyRO's Avatar
Re:running lean?
Gary - I think I agree with your whole reply. I'm sure that at some point (before my exposure to diesels even), I though that blowing more boost would automatically give more power.<br><br>And then those of us who ask and or seek the truth, learn differently.<br><br>- JyRO
Old Jul 17, 2003 | 02:29 PM
Re:running lean?
question then, If i have no signs of smoke, then is it time to up the stock injectors to match the rest of the upgrades?<br>and if i do that, how much will the egt raise? i feel i am pushing it now.
